Sponsored by:
Sponsored by: DashLynx
lowering Springs for my Mustang
Old 04-13-2014, 08:21 PM
kevin_pianoman
kevin_pianoman's Avatar
Default lowering Springs for my Mustang
Hey guys. I have a 1998 Mustang GT. I just replaced my factory rims which were 16 inch with 17 inch. It looks much better but still has quite a bit of room in the wheel Wells. I want to buy lowering Springs but was wondering if they will screw up my new tires? I have heard that lowering Springs can mess up alignment and chew up tires on the front. Please let me know. Thanks guys!
kevin_pianoman is offline
Old 04-13-2014, 08:35 PM
2011V6Nicole
2011V6Nicole's Avatar
If you get an alignment after you put them on it shouldn't mess up your tires.
2011V6Nicole is offline
Old 04-13-2014, 08:40 PM
kevin_pianoman
Do you have to get different shocks when lowering the car?
Old 04-13-2014, 11:22 PM
2011V6Nicole
Im not sure about your body style, I know for mine the general consensus was if you're lowering it 1.5in or less you should be ok with the stock shocks and struts, more than that You are suppose to get aftermarket ones.
Old 04-14-2014, 10:32 AM
Soldier GT
Soldier GT's Avatar
Depends on the drop but you will have to get caster camber plates. Learned that one the hard way..
Soldier GT is offline
Old 04-15-2014, 01:31 PM
nightshadow23
nightshadow23's Avatar
You don't have to get new shocks, but it's the perfect opportunity to upgrade them (while you have the strut assembly out). If it's been a while since you've changed them, you might as well.
nightshadow23 is offline
Old 04-15-2014, 02:10 PM
AJ06GT
AJ06GT's Avatar
New/upgraded shocks are always good with a set of lowering springs to help with handling. If you only drop about an inch you can probably get it aligned without needing extra parts.
AJ06GT is offline
Old 04-20-2014, 07:18 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Just bring some caster camber plates like these to the alignment shop and you won't have any additional tire wear after you lower it.
UPRSharad is offline
Diode Dynamics
28
05-26-2022 12:02 PM
01moostanggt
08-17-2015 01:22 PM
robjh22
08-17-2015 07:35 AM
WDScott
08-17-2015 06:38 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: lowering Springs for my Mustang
