valve springs
high-flow oil pump... may want an oil cooler too
Cooling upgrades.
May need to blueprint the short-block
+1. at least full valvetrain work. maybe some cams that'll actually give power that high. high flow oil pump and cooler a must. and cooling upgrades yes. probably want to balance and blueprint everything. i think that'd do it.
but why go that high without the cams to make that power?
And why do you think you want to rev to 8500rpms? Did you just grab that number out of thin air or is there reason you want to window your block? One thing for sure... You will NOT do it repeatedly with stock internals, even IF there was no rev limiter.
I have had mine to 6700 a couple of times during some burnouts but try to stay aroud 6200 to 6500 when I pay attention to the tach...dont know at what rpm she will blow
