Mobil 1 Synthetic and filters
Old 06-19-2007, 07:44 PM
sixbanger06
sixbanger06's Avatar
Default Mobil 1 Synthetic and filters
So at my next oil change I want to switch to a full synthetic. I called Mobil 1 and asked what they recommended for my car. They said to use the 5W20 Mobil 1 full synthetic (Change every 10,000 miles)or the Mobil 1 entended performance full synthetic (Change every 15,000 miles). My next question was ok, well... what filter should I use, and obviously I will have to change the filter every 3-5K miles. The tech said no, just change the oil and filter at the same time. He advised me these two oils meet Ford WSS-M2C930-A standards, so they will NOT void the warranty (I did double check this afterwards).
So my next question was- How the heck can these same filters that are being used with other oils and are being replaced after 3-5K miles last 10K-15K miles? He said this oil doesnt cause the sludge and break down like other oils do, so there is no need to replace the filter. Now, I would say that they are full of sh**, however he recommended a mobil 1 filter, so if they were smart and trying to make money, they would say yea, replace the filter every 3-5K miles.
He also pointed out that Mobil- 1 full synthetic oils are being used in some higher end cars right from the factory- such as corvettes, cadillacs, VW, and some others, and that they recommend only changing the oil every 7-10K miles.
So, I am going to go full Synthetic, the question is, how long is it safe to leave one of these 10-15K mile oils in?
sixbanger06 is offline
Old 06-19-2007, 08:09 PM
callahan
callahan's Avatar
Default RE: Mobil 1 Synthetic and filters
I use synthetic and still change every 3,000 miles. It may be excessive, but, it makes me feel better.
callahan is offline
Old 06-19-2007, 08:14 PM
howarmat
s197 Junkie
howarmat's Avatar
i change everything at 4-5k miles
howarmat is offline
Old 06-19-2007, 09:15 PM
s197richie
I ♥ Acer
s197richie's Avatar
ORIGINAL: callahan
+1 it's cheap insurance
Richie
s197richie is offline
Old 06-19-2007, 09:19 PM
Goldenpony
Goldenpony's Avatar
I change every 5K miles. If your car is still under warranty, I wouldn't go any longer than 5K between changes. After warranty you could probably easily go 10K-15K miles, but I'd change filters at least every 5K miles.
Goldenpony is offline
Old 06-19-2007, 10:48 PM
owero01
owero01's Avatar
I change every 5000 no matter what.
owero01 is offline
Old 06-19-2007, 11:11 PM
22kart22
22kart22's Avatar
go the distance. my dad works for exxonmobile.
I know
22kart22 is offline
Old 06-19-2007, 11:24 PM
drbobvs
drbobvs's Avatar
I change my Mobil 1 and filter (non Mobil 1) every 7500 miles in my DD Suv's without ever an issue, but with my Stang I'm very over zealous and change it every 2-3 months. This usually comes out to be only about 2,000 miles. I change it again before winter storage too. I really just enjoy taking care of it.
drbobvs is offline
Old 06-19-2007, 11:30 PM
06GT4RAD
06GT4RAD's Avatar
I use the Mobil 1 5w20 with Motorcraft Filter and change every 5K
If you want to stretch the oil change intervals to 10k I would at the very least change the filter at 5k and then top off. Call Mobil 1 back and ask him for a written warranty that if the motor has a oil related failure by using his guidelines will Mobil 1 pay for all repairs. Because I assure you whenFord asks to see proof of your oil and filter changes every 5k and you show them you waited until 10k they will void your warranty.
Richard
06GT4RAD is offline
Old 06-19-2007, 11:41 PM
Meangreen1200
Meangreen1200's Avatar
Ditto! every 3K or 3 months.
ORIGINAL: callahan
Meangreen1200 is offline
Quick Reply: Mobil 1 Synthetic and filters
