Are 20's a performance killer?
Old 07-03-2007, 04:28 PM
06musgt
06musgt's Avatar
Default RE: Are 20's a performance killer?
thats why i wanna keep my 17's because if theres a difference between 20's and 18's.theres gotta be a slight difference between the 18's and 17's wouldn't you think?
06musgt is offline
Old 07-03-2007, 06:24 PM
TrIpOd
TrIpOd's Avatar
ORIGINAL: Black06GT40324
rotating mass hurts . . . and it changes your gear ratio . . .
LARGER RIMS DO NOT CHANGE YOUR GEAR RATIO!!!! only if the tires you purchase are a larger diameter than the stock wheels which the diameter is 27.2. the most common size for 20" rims is 255/35/20 which is a 27" diameter. thats not enough to change your gear ratio.
TrIpOd is offline
Old 07-03-2007, 07:08 PM
Dex
Dex's Avatar
hes right
Dex is offline
Old 07-03-2007, 10:22 PM
Mustang3GT07
Mustang3GT07's Avatar
They hurt your car alot!
Mustang3GT07 is offline
Old 07-03-2007, 10:30 PM
PLstang
PLstang's Avatar
I'm sorry I dont know much about the technical side of the issue, I just never cared for them on the S197's.
PLstang is offline
Old 07-03-2007, 11:23 PM
wozz
wozz's Avatar
All depends on the wheels fitted. For example my friend lost 52lbs of weight on the wheels by changing from a 16" stock wheel adn tyre to a 17" wheel with semi slick tyres. Made quite a big difference and as rotating radius was identical speedo was spot on.
If you have chrome wheels chances are yes there hurting your performance. If you went with a light weight 20" set they could possibly be lighter than the stock 18's if you get some decent lightweight wheels.
wozz is offline
Old 07-04-2007, 12:48 AM
FastLane034
FastLane034's Avatar
I HATE 20's on s197's.... People say "they really set off the car" yeah well I just think they look horrible. The ONLY 20 acceptable is a chrome or black bullitt, but still not even close to worth it for the performance loss.
FastLane034 is offline
Old 07-04-2007, 01:43 AM
brad281
brad281's Avatar
20's kill performance. You can feel it the first time you drive the car. I really like how they look and that makes it up for me. I also have a vert whcih is also a performance killer in the extra weight. Ride is stiffer, but car does handle better with smaller and stiffer bfg sidewalls.
brad281 is offline
Old 07-04-2007, 02:51 AM
Treatz
Treatz's Avatar
the same can be said for a lighter wheel.
I myself was looking at some ultra light 18 and 19's which SHOULD weigh less then my stock 17's
www.tirerack.com has a nice set of ASA AR1's in 18' which look like the FR500 mustang wheels.
they weigh 23lb's per wheel on 18 x 8
|SIDEBAR| what do the Stock 17's on a GT weigh?
Treatz is offline
Old 07-04-2007, 02:58 AM
Rt1Rebel
Rt1Rebel's Avatar
To each their own, but I just don't like the look. Stock 18s are as big as I think looks right, never mind the performance and logistic problems.
Rt1Rebel is offline
Quick Reply: Are 20's a performance killer?
