Need Help with these codes?
Old 06-15-2008, 08:27 PM
Kipp07GT
Kipp07GT's Avatar
Default Need Help with these codes?
Ok, my 07 Gt is freaking out on me, I pulled 3 codes from my SCT Handheld and dont know what they are. The car is not wanting to drive when I put the gas peddle down, im thinking its the Drive By Wire tech. **** thats on it. You can put your hand at the throttle body where the sensor is connected and just barely push it and the car will start wanting to choke out and not run at all. These are the codes if anyone can help me. P2104 P2107 P2110. The car has never had one problem until now. Do they make a kit to convert the DBW to a throttle cable, because im not liking the whole electronic deal. Thanks Kipp
Kipp07GT is offline
Old 06-15-2008, 08:44 PM
hammeron
hammeron's Avatar
Default RE: Need Help with these codes?
my best guess, is it's probably the
throttle body that has failed.
other possible causes would be:
wiring or pcm
hammeron is offline
Old 06-16-2008, 03:54 PM
Kipp07GT
Kipp07GT's Avatar
Anyone else? Im about fed up with it, the 3V is about to get yanked out and a 4V put in its place.
Kipp07GT is offline
Old 06-16-2008, 04:42 PM
157dB
Cut & Paste Expert
157dB's Avatar
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
157dB is offline
Old 06-16-2008, 06:40 PM
Kipp07GT
Kipp07GT's Avatar
P2107 - Throttle Actuator Control (TAC) Module Processor
Description: The electronic throttle control (ETC) area of the powertrain control module (PCM) failed the
self-test. The concern could be the result of an incorrect throttle position (TP) command, or
TAC motor wires shorted together.
Possible
Causes:
 TAC motor wire shorted together
 TAC motor circuit wires short to PWR
 Damaged electronic throttle body (ETB)
 Damaged PCM
Diagnostic
Aids:
A TAC motor circuit PID reading may indicate a concern, if available.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test DV .
P2110 - Throttle Actuator Control (TAC) System - Forced Limited RPM
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced
limited RPM.
Possible
Causes:
Diagnostic
Aids:
This DTC is an informational DTC and may be set in combination with a number of other
DTCs which are causing the FMEM. Diagnose other DTCs first.
All GO to Pinpoint Test QE .
P2104 - Throttle Actuator Control (TAC) System - Forced Idle
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced idle.
Possible
Causes:
Diagnostic
Aids:
Thanks 157db, these are my problems, now what is my fix? Cause I have no clue as to why they are doing this? Seems to me the TB is my concern, damn electronics, wish it were cable fed.
Kipp07GT is offline
Old 07-17-2010, 10:13 AM
shanec
shanec's Avatar
I am debugging a P2107.
What manual does the stuff below come from? I'd like to read more on this.
Possible
Causes:
 Damaged PCM
Diagnostic
Aids:
limited RPM.
Possible
Causes:
Diagnostic
Aids:
Possible
Causes:
Diagnostic
Aids:
shanec is offline
Old 07-17-2010, 11:15 AM
157dB
Cut & Paste Expert
157dB's Avatar
HERE
Try those
157dB is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Need Help with these codes?
