Manual Transmission Fill Technique.
Old 08-04-2008, 07:39 PM
Dragon Stang
Dragon Stang's Avatar
Default Manual Transmission Fill Technique.
I have read some posts on here that mention filling the manual 3650 tranny can be a challenge. I just filled mine and never spilled a drop. All I did was push a funnel into a length of hose, snaked it down along the exhaust behind the engine and put the end into the fill hole.
Pictures attached:
[IMG]local://upfiles/78734/358C8A1554964557BC906E2EA42B9A82.jpg[/IMG]
[IMG]local://upfiles/78734/C40E5E7E29574057B7646C8561644829.jpg[/IMG]
[IMG]local://upfiles/78734/C8105EC22C4248BAB5EA1091D43C0597.jpg[/IMG]
Dragon Stang is offline
Old 08-04-2008, 07:41 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: Manual Transmission Fill Technique.
haha....i was just talking about this in the RP thread.
You can also feed it through the shifter hole inside the car if you want. Either way work better than using a pump IMO
howarmat is offline
Old 08-04-2008, 08:05 PM
Dragon Stang
ORIGINAL: howarmat
Yes, I would have done it through the shifter hole but since I installed the MGW, I didn't want to poke holes in the Dynamat or have to peel back all the layers of rubber etc.
Old 08-04-2008, 08:32 PM
ym42
ym42's Avatar
What did you use to fill the trans? And why?
ym42 is offline
Old 08-04-2008, 08:50 PM
Dragon Stang
ORIGINAL: ym42
I used a simple household kitchen funnel and a length of Sunroof drain hose I cobbed from work. Makes it easy and clean to fill the tranny without any pumps or waste.
Did you look at the pics?
Old 08-04-2008, 10:14 PM
Simon1
Simon1's Avatar
I tired using a funnell and it sucked. Took 30 minutes for one bottle to get in. Bought a pump for 8.99 and finished in 5 minutes.
Simon1 is offline
Old 08-05-2008, 12:13 AM
ym42
ym42's Avatar
I think you did not get my question. What fluid type and brand did you use and why? I got HOW you did it LOL
ym42 is offline
Old 08-05-2008, 07:38 AM
Dragon Stang
ORIGINAL: ym42
I used Mobil 1 Synthetic ATF. My next fill will be RP Syncromax.
Old 08-05-2008, 07:43 AM
Dragon Stang
ORIGINAL: Simon1
I had mine filled in a leisurely 5 minutes. Mind you, ATF flows like water. But, it was easier than taking out the center console to access the fill hole through the shifter hole. And it was a lot cheaper than a pump. The beauty of it is that not one single drop was spilled or wasted.
Old 08-05-2008, 12:22 PM
Z06 Killer
Z06 Killer's Avatar
Nice! I was about to pull my shifter boot apart!
Z06 Killer is offline
Quick Reply: Manual Transmission Fill Technique.
