NEED HELP - Not running right
Old 09-05-2008, 05:10 PM
nm3
nm3's Avatar
Default NEED HELP - Not running right
I disconnected (just flipped the grey levers) the PCM connectors to get the code on the PCM for my Pro-Cal Tool, but did not totally remove the connectors. Then I thought I better check to see if the battery needed to be disconnected ( I hadn't disconnected it) . Low and behold I should have. I flipped back the levers to the connectors and now the car is not running right. Is this correctable with disconnecting the battery for a while? Or did I royally F something up?
Thanks in advance!
nm3 is offline
Old 09-05-2008, 05:15 PM
svt93style
svt93style's Avatar
Man I am a bit confused about what your talking about here, but in my experience if you disconnect the ground wire on the battery for 15-20 the computer should reset itself.
It might act a bit funny for a bit because it is re-learning but your should be fine.
svt93style is offline
Old 09-05-2008, 06:29 PM
deekum1627
deekum1627's Avatar
i think you should be fine
deekum1627 is offline
Old 09-05-2008, 06:59 PM
hammeron
hammeron's Avatar
let's hope so and you might have.
i would disconnect the negative battery
terminal, reseat the pcm connectors,
hook the battery back up, cross your
fingers, start the car and see how she runs....
Thanks in advance!
hammeron is offline
Old 09-05-2008, 07:47 PM
moosestang
moosestang's Avatar
I think it's all in your head. Whenever you disconnect an electrical sensor, the manual will tell you to disconnect the battery. They are mostly being over cautious.
moosestang is offline
Old 09-05-2008, 08:45 PM
nm3
nm3's Avatar
Well, it's not in my head and after disconnecting the negative terminal on the battery for 3 plus hours, and following the new battery procedure in the manual, it's still not right. Sounds/feels like it's not firing on all cylinders. Also, I have a check engine light. Any more ideas are greatly appreciated. It'll never make it to my dealer as they are 30 miles away. I'll have to go to a local dealer.
nm3 is offline
Old 09-05-2008, 10:40 PM
East87
East87's Avatar
lol hammeron i always think you're writing poetry to answer peoples' questions/problems. the spacing makes it look almost like haiku.
"battery problems
reconnect the terminals
you are good to go"
or a sonnet or something...hahaha
East87 is offline
Old 09-05-2008, 10:46 PM
Nuke
Nuke's Avatar
I don't understand why the OP had to disconnect ANYTHING to get the PCM code. Isn't that legible on the outside of the housing? Or am I thinking of something else?
Nuke is offline
Old 09-05-2008, 10:57 PM
hammeron
hammeron's Avatar
someone else said something similar
awhile back......maybe i'll try making my sentances
run out a little further to the right, kinda like this......
on a side note, the only other time i've heard the
words haiku and sonnet at the same time, was in
one of steven hawking's videos.....
"battery problems
you are good to go"
hammeron is offline
Old 09-05-2008, 11:00 PM
hammeron
hammeron's Avatar
hey nuke, sometimes FRPP has you look
at the label on the side of the PCM, which
you can only see if you pull the PCM out
i had to do it for my pro cal, also
hammeron is offline
Quick Reply: NEED HELP - Not running right
