Twin Turbo S197 numbers at #19
Old 09-16-2008, 09:53 AM
  #21
silverpoison
silverpoison's Avatar
The point I was trying to make earlier on the thread is the fact that a blower set-up is ok for the street (damm I had one for over a year), however since my car will not be driven on the street for more than 2000 miles a year I decided to go TT, the first order was a single 76mm but I changed the order and I don't regreat that. I had a little KB2.4 before and I ran a 6.9 on 1/8 banging gears on the 5 Speed trans. Now is making 150 more rwhp and is with a built automatic, for of you that probably don't know an Automatic will rob a lot more rwhp than a stick.
Another reason why I went TT is because I only took 1K out of my pocket after I sold the blower, upgraded HE, Ice Box, Long Tube Headers, 8 Rib set-up, Tensioner, set of pullies.
The car has totally no traction on street tires, the power blows the tires right away even on the street tune.
silverpoison is offline
Old 09-16-2008, 11:11 AM
  #22
Brian_Zinchuk
Brian_Zinchuk's Avatar
I wasn't knocking your set up at all. I was just trying to make a point that there are stangs out there with S/Cers making huge numbers on the track.
Brian_Zinchuk is offline
Old 09-16-2008, 12:10 PM
  #23
MustangGT0405
MustangGT0405's Avatar
That leads to the best thing about turbo's, a boost controller
That way you can run 4psi in 1rst 8 psi in second, and 12psi in 3rd and 4rth.
Wish I could that with my twin screw.
MustangGT0405 is offline
Old 09-16-2008, 04:46 PM
  #24
blueherd02gt
blueherd02gt's Avatar
And this proves what? Turbos are the f/i of choice in most production vehicles for a reason. That car you're talking about is a mystery to most because of the coin thrown at it by that shop to be "the fastest 3v". The US government is another proponent for throwing the proverbial dollar at each and every problem... That being said the f1 centri is a beast, but unless you plan on a track only ride there are options. One is a turbo because of it's abiliaty to produce boost at a faster rate with current designs, and the ability to swap turbos easily for different applications.
Originally Posted by Brian_Zinchuk
you guys are going on about this twin turbo stuff when the fastest 3 valve S197 is powered by a centri (procharger).
blueherd02gt is offline
Old 09-16-2008, 06:07 PM
  #25
EagleStroker
EagleStroker's Avatar
Thumbs up
Turbo is the way to go to make power, no need to build a insane engine with PP heads, stage 3 cams, Long tubes, TB's and all that BS. Just a turbo kit and that's it.
yea it's not required but it sure is fun =) and your motor benefits from it, anything that helps air in or out, I can't wait til I can go tt on my car, gunna be a good day impressive numbers
EagleStroker is offline
Old 09-17-2008, 07:04 AM
  #26
moosestang
moosestang's Avatar
Could you enlighten those of us that don't know the answer? My guess would be cost. The little turbos in most of these cars are cheap compared to any supercharger head unit.
moosestang is offline
Old 02-20-2009, 01:47 PM
  #27
silverpoison
Update, Car is getting a Full Cage and More boost, shooting for '9.9's
Old 02-20-2009, 02:04 PM
  #28
MustangGT0405
Glad to hear it. How have the turbo's been holding up in street driving?
Old 02-20-2009, 02:51 PM
  #29
moosestang
moosestang's Avatar
I know the fastest '05 is Justin from JPC, ohh no is acutally a 88mm single turbo from modular depot, I am not trying to be the fastest '05. My goal is to run a 9'second one day and I think my set-up will allow me to do it. I was just posting the numbers of my set-up. Maybe you should change your whipple and run a Procharger + juice...lol
Dammit! I got sucked into an old post.
So what happened to the track numbers?
Old 02-20-2009, 02:53 PM
  #30
explict
explict's Avatar
Sounds like fun!
When are you going to hit the track?
explict is offline
Quick Reply: Twin Turbo S197 numbers at #19
