McLeod RST - Looking for Install Tips-sticky above!
Old 11-25-2008, 02:24 PM
  #21
hammeron
hammeron's Avatar
another question i have is, how to
best prepare the transmission input
shaft, before installing the new slave,
should it just be wiped down, or should
grease be applied....
also what about the very end of the shaft,
should it be greased at all before installing
into the pilot bearing...
hammeron is offline
Old 11-25-2008, 03:42 PM
  #22
sactown
sactown's Avatar
I passed your question on to Lee here is his reply:
Wipe the input shaft clean, or spray it down with acetone or paint thinner. Next, inspect the shaft for nicks burrs etc. File/fix if necessary. Apply a THIN film of lithium grease to the input shaft making sure that the disc slides smoothly on the input. No application of anything is needed on the lead of the input as all of the grease necessary is already in the pilot bearing.
sactown is offline
Old 11-25-2008, 03:51 PM
  #23
hammeron
hammeron's Avatar
bravo sactown! you must have a hot line
to Lee's desk......
sadly, i do believe i'm all out of questions.....
as soon as my mcleod billet steel flywheel
arrives, i'll be able to start reassembling.....
hammeron is offline
Old 11-25-2008, 04:03 PM
  #24
sactown
sactown's Avatar
to Lee's desk......
LOL!
What happened with the flywheel? Backordered? You know I could have made you a great deal on a Specs flywheel!
sactown is offline
Old 11-25-2008, 04:21 PM
  #25
hammeron
hammeron's Avatar
well up until a few days ago, i had been
considering reusing the stock flywheel....
the issue with less surface area coupled
with the hassle of taking it somewhere,
made the choice to purchase a new
one less painful.
Originally Posted by sactown
LOL!
hammeron is offline
Old 11-25-2008, 06:40 PM
  #26
hammeron
hammeron's Avatar
ok moose, it turns out i still had the upper
bolts bagged separately from the rest.....
what i can say for sure is, the bolts that go
in the top 2 mounting holes, are not
the longest bolts.....
i did mix the 2 long ones with the remaining shorter
ones, so i can't say without looking, where they
are supposed to go...
Originally Posted by moosestang
I'm talking about the two upper transmission mounting bolts, the ones that hold it to the block. I'm pretty sure the two top bolts are longer than all the others, but wanted some confirmation.
hammeron is offline
Old 11-25-2008, 09:05 PM
  #27
HaneyMotorsport.Com
Banned
HaneyMotorsport.Com's Avatar
casey, you are the man! thanks, your pictures
answered one of my other questions, which was,
"which clutch disk goes closest to the flywheel?"
your pics indicate that the one labeled "bottom"
is the answer.
that sure is one good looking setup.
moose, funny thing is i had those two
upper transmission bolts bagged by themselves
for a while......then after i removed the remaining
bolts, i threw them in the same bag...
i remember now you mentioning that maybe those
were a different length, but i forgot about it
until you mentioned again....
i'll look in the bag tonight, to see if all the
bolts are the same size or not.....
No Problem!! I think you got all the answers from everyone here.
Casey
HaneyMotorsport.Com is offline
Old 11-26-2008, 04:18 AM
  #28
moosestang
moosestang's Avatar
Well that sucks! I was able to thread them into the top holes all the way without issue. I hope I can remove them without issue.
They looked like they would stick way out in any of the other mounting holes.
moosestang is offline
Old 12-05-2008, 02:15 PM
  #29
hammeron
hammeron's Avatar
see first post, first page, for project
update
hammeron is offline
Old 12-05-2008, 02:21 PM
  #30
moosestang
moosestang's Avatar
So is it in? did you test drive it yet? Tackling a clutch install is very satisfying and very bad for the back.
Quick Reply: McLeod RST - Looking for Install Tips-sticky above!
