having a problem
Old 12-03-2008, 09:30 PM
09blkgtcal
09blkgtcal's Avatar
Default having a problem
Whenever I let my car sit over night and drive it the next day my steering wheel shakes when I drive over 60 mph but it goes awa after a drive from a little while. It'll even happen when I let my car sit for like 5hrs. I checked my tire pressure and it's fine. Anyone know what this could be?
09blkgtcal is offline
Old 12-03-2008, 10:59 PM
hammeron
hammeron's Avatar
i'm not sure whats happening exactly, but
one thing i would probably do, is to swap the
front and rear tires.....if the shaking went away,
i would know there's a problem with one or both
of the tires
hammeron is offline
Old 12-03-2008, 11:16 PM
Connie07
Connie07's Avatar
Your tires are probably low on tread and/or don't hold air as well as they should. You mentioned your tire pressure was good. What about tread?
Connie07 is offline
Old 12-04-2008, 07:03 AM
Nuke
Nuke's Avatar
Most tires will develop flat spots after sitting for awhile. Some are worse than others. The colder temps increases this and also the duration until the tires warm up and the flat spot dissipates. It's common.
Nuke is offline
Old 12-04-2008, 07:08 AM
05 Mustang
05 Mustang's Avatar
+1^^
you're just getting flat spots from the car sitting, mine does it too. nothing to be concerned with as long as it goes away after you drive it. if it didn't go away, I would just take the car to a shop and have them re-balanced.
05 Mustang is offline
Old 12-04-2008, 07:19 AM
SaddleUp
SaddleUp's Avatar
Mr Nuke is correct.....I have the same thing occur around these parts when I let the cars sit for awhile before driving them. It gets worse if it is during colder weather. It may shake slightly for a while, but after a little while of driving it always goes away. I've even noticed it on my non-mustang (Jeep~!) vehicle.
SaddleUp is offline
Old 12-04-2008, 09:36 AM
Nuke
Nuke's Avatar
Yep, happens to BOTH of my SUV's, too...
Nuke is offline
Old 12-04-2008, 04:17 PM
157dB
Cut & Paste Expert
157dB's Avatar
Flat spots.
A co-worker filled another co-workers front tires
with some water. All was good until the temps
dropped below freezing then the ice slugs threw
the front end for an awful shakin.
Maybe some moisture in your tires?
Does it coincide with lower below freezing temps?
157dB is offline
Old 12-04-2008, 08:32 PM
09blkgtcal
09blkgtcal's Avatar
thanks for the feedback guys, the tread is fine and the tires haven't seen anything lower than 30 degrees
Old 12-06-2008, 05:07 PM
09blkgtcal
09blkgtcal's Avatar
are you saying that its the parts not the wheels??
Quick Reply: having a problem
