boost creep with hellion turbo kit need help
Old 12-28-2008, 03:23 PM
  #21
bobby1110
bobby1110's Avatar
i still need help with this. they just knocked it right off of hear. i hate when they do that. i live just out side of charlotte, nc. if some one is near that can help me find out the problem just pm me or something. thanks
bobby1110 is offline
Old 12-29-2008, 07:30 AM
  #22
bobby1110
bobby1110's Avatar
her is how i have it hooked up. the first one is how it was hooked up originally. the second is how i have it hooked up now.
Attached Thumbnails boost creep with hellion turbo kit need help-originalturbosetup.jpg   boost creep with hellion turbo kit need help-turbosetup.jpg
Old 12-30-2008, 03:07 AM
  #23
Simon1
Simon1's Avatar
I will look in the box for my boost controler tomorrow and see what the vacuum line plumbing looks like.
Simon1 is offline
Old 04-15-2009, 06:51 AM
  #24
yanrider
yanrider's Avatar
bump, hi I'm new here and have the same problem (well I'm not sure its a problem but)
did you resolve this creep issue?
I was always getting 5-6 psi which was ok, but I went over the system after a week of driving and notieced a few clamps where loose and or slipped off so I tightened those up and now I get quicker spool, and 2 psi of creeep in 3rd gear and around 4psi in 4th...my tune should be good for it but it could be risky
input?
yanrider is offline
Old 04-15-2009, 07:21 AM
  #25
one eyed willy
one eyed willy's Avatar
the wastegate that comes witht hose kits is a 38mm turbonetics. Turbonetics 38mm wastegates are known thru out the turbo community to spike. the valve that relaease the pressure does not open all the way. i recently used one on y set up and it spiked, i will be replacing it with a tial or b&g. others that i have spoken too that had the same issue just replaced it and the problem was gone, no other modifiactions done,just replaced the wastegate.
one eyed willy is offline
Old 04-15-2009, 07:32 AM
  #26
yanrider
yanrider's Avatar
and this WG bolts right on?
yanrider is offline
Old 04-18-2009, 11:17 AM
  #27
Simon1
Simon1's Avatar
Yes. A waste gate will bolt right on. Usually two small bolts on one side and two on the other.
Simon1 is offline
Old 04-29-2009, 08:53 PM
  #28
yanrider
yanrider's Avatar
cool I'll look into that. Also, does anyone have issues with boost leaks between the MAF and the intake? I had tightened all my clamps, was fine for a few rides but now I hear a leak again, and all seems tight? I guess I'll just look deeper
yanrider is offline
Old 04-29-2009, 10:10 PM
  #29
CaliSpecial08Gt
CaliSpecial08Gt's Avatar
Bring that to a shop n take it off the road. Ull burn out your turbo and the wastefste. It's gotta be the tune. Not safe at all
CaliSpecial08Gt is offline
Old 04-30-2009, 12:53 AM
  #30
Simon1
Simon1's Avatar
You shouldn't be able to hear a leak while standing at the intake since there should be no pressure built if the motor is not under load.
If you have boost creep, it is generally narrowed down to a malfunctioning wastegate, improperly sized wastegate, malfunctioning boost controler.
I have never heard of a tune causing boost creep and can't see how it's possible.
Simon1 is offline
Quick Reply: boost creep with hellion turbo kit need help
