Gearing question/opinions please
Old 05-24-2009, 12:53 AM
Lankers
Lankers's Avatar
Default Gearing question/opinions please
I have an 05 GT with a 5-speed. I was planning on getting 4:10's, but I wanted to see what you guys thought. My concern is that I'll end up losing time shifting so frequently. Basically 3:73's or 4:10 on a 5 speed?
Lankers is offline
Old 05-24-2009, 01:30 AM
desslok40
desslok40's Avatar
The most important decision when getting new gear ratio is getting it done by someone who knows what the hell they are doing, seriously that is the biggest issue !!!
I would go with 4.10s for manual, 3.73s for auto.
IMHO
desslok40 is offline
Old 05-24-2009, 09:51 AM
2007Vert
2007Vert's Avatar
I would agree with FRPP 4.10a gears with a 5 spd and 3.73 with an auto. If you were going to go with F/I then I would install 3.73 gears and with N/A use the 4.10 gears.
2007Vert is offline
Old 05-24-2009, 07:26 PM
candymanjl
candymanjl's Avatar
it depends how much power you're going to run. all motor and the 4.10's may work out well for the strip. boosted or spraying a big shot and the gear may be a liability. if you loose traction or have to make an extra shift it may not help your time.
candymanjl is offline
Old 05-24-2009, 09:32 PM
BruceH
BruceH's Avatar
BruceH is offline
Old 05-25-2009, 12:13 AM
.boB
.boB's Avatar
That all depends on usage.
Unfortunatly, there's no perfect gear; unless it's in a car dedicated to one purpose. For the rest of us, it's all a comprimise.
You give a little, and you take a little. You have to decide where the correct balance is. I'd love to have a lower first gear. But I'd hate to lose my high speed cruising.
.boB is offline
Old 05-25-2009, 12:30 AM
Lankers
Lankers's Avatar
currently I have a K&N air filter, Steeda high flow elbow (not CAI), custom tune, short throw shifter, and Pypes mufflers. I'm planning on adding some BBK shorties, FRPP Hot Rod Cams, and gears. I'd love to go FI, but unfortunately it's just not in the budget. My daily commute only gets up to 50mph so I'm not worried about that. Even if I go to the neighboring town, it's only gonna be 60mph.
Lankers is offline
Old 05-25-2009, 01:17 AM
BruceH
BruceH's Avatar
BruceH is offline
Old 05-25-2009, 01:32 AM
dn37110
dn37110's Avatar
IMHO
i have always been told to use 4:10 with auto and 3:73 with 5 speed. I have a auto with a 4:10 and my friend has manual with 3:73 and we stay pretty competitive with each other
dn37110 is offline
Old 05-27-2009, 12:57 AM
One Bad Stang
One Bad Stang's Avatar
IMHO
+1000 on finding a good shop/mechanic to install the gears. i am still going throug a battle with the original installer of my gears. they tried 3 times before i took the car elsewhere, only to find out they (the original installer) had messed up the install so bad the pinion gear had cut a new groove into the ring gear. it has been a complete nightmare, but the original shop bought me a new set of frpp gears, and i am still working on reimbursment for the cost of diagnosing the issue and installing the new set of gears.
but aside from the noise issue i went through/am going through, the gears themselves are great! i chose the 4.10's and i love them. 2300 rpm @ 65mph on the highway, great accelleration arround town and on the highway, and another factor for me was that 3.73's probably wouldn't have been much different from the stock 3.55's my car came with. i wouldn't take a cross-country road trip with the new gears, but they fit my daily routine perfectly.
One Bad Stang is offline
Quick Reply: Gearing question/opinions please
