Thinking of staying N/A mods?
Old 06-08-2009, 04:24 PM
'00project
'00project's Avatar
How much HP do you want to make? I just read MM&FF June 09 mag that has a write up on it. It made 27 more HP and a little more with a Whipple single blade. I was going to add a link, but it is not on the site yet. Should still be on the stands.
'00project is offline
Old 06-08-2009, 07:25 PM
bonestang
bonestang's Avatar
LT Headers and x/h pipe will get you a nice chunk of power. The MAC and Kooks systems made 40HP on a supercharged motor. They wouldn't make that much on a N/A motor, but it would still be a nice gain, plus awesome sound.
http://www.mustang50magazine.com/tec...ers/index.html
If you are planning on cams then the longtubes will be even more beneficial. I got a set of Kooks on the way so I'll know pretty soon if it was worth the money.
bonestang is offline
Old 06-08-2009, 10:04 PM
East87
East87's Avatar
The C&L intake manifold is a total flop for NA cars apparently. Definitely look in other directions if staying NA is truly your course of action. I'm thinking about staying NA myself, as my friends who are FI are without their cars for months at a time because different problems keep arising once you cross that 10-12psi threshold...
4.10s are on the way, and I'm hoping to pick up cams and Kooks LT's/catted H sometime in the more distant future.
East87 is offline
Old 06-09-2009, 03:10 AM
I8ACHEVY
I8ACHEVY's Avatar
yeah, saw the Kooks out there on Brenspeed's site. WOW, big chunk out of the old wallet on that one! Would probably lean towards the MAC LTs as they got the 2nd most decent write up (next to the Kooks, of course). Still trying to figure out if emissions would be an issue in NC with the catless H pipe. But now a new question to consider...do LTs cause emissions problems also. And if I decided to get the LTs, and lower about 1.5 inches, are there ground clearance issues?
I had a '71 Torino with Hooker LTs and that SOB had clearance issues all the time.
Thanks!
I8ACHEVY is offline
Old 06-09-2009, 08:40 AM
East87
East87's Avatar
If your state checks to make sure all of your oxygen sensors are activated, you might run into trouble. LT headers might require you the tune to disable 2 of the O2 sensors. Also, emission problems result from the catless midpipe. You might not pass a sniff test or a visual test in that circumstance. I'm not familiar with NC's inspection process though.
East87 is offline
Old 06-09-2009, 11:42 PM
rpatyna
rpatyna's Avatar
my mods-Rob
http://www.cardomain.com/ride/2460665
rpatyna is offline
Old 06-10-2009, 07:21 AM
07 GT/CS
07 GT/CS's Avatar
I have the mac LT's they fit great sound good and are very well made. Headers will smooth out the exhaust note so a good axle back exhaust is a nice addition. For you questions on emmisions, both mac and kooks are more of a mid length header design even though they are sold as longtubes. that makes them more tune friendly allowing you to get an emmision legal tune from brenspeed, bama ect (depending on you state if your Cali sorry no LT's). You wont have any of the clearance issues associated with true long tubes and for some reason mac and kooks seem to make better numbers that borla, bassani ect which are true full length, I've got my headers, x pipe and high flow cats on now, dyno # in my sig. and i don't even have a tune yet. granted my numbers are alittle higher because i'm at sea level, any lower i'd need a snorkle on my car. I'll let you all know the numbers after the intake and tune are in. also I have the stock motor mounts and do not have any rubbing issues either. hope this helps you some. If you have any more questions on headers there is also alot of knowledge around this forum.
07 GT/CS is offline
Old 06-13-2009, 10:48 AM
I8ACHEVY
I8ACHEVY's Avatar
I neglected to mention throttle body as I have not seen many people mention it as an upgrade. Is it worth it? Thoughts? What brand/size? Will it bolt right up with the JLT2 CAI?
Thanks!
I8ACHEVY is offline
Old 06-13-2009, 05:48 PM
East87
East87's Avatar
Thanks!
I've heard that the BBK throttle body causes a lot of problems. There's not much to improve over stock until you're very highly modified.
East87 is offline
Old 06-15-2009, 08:41 AM
I8ACHEVY
I8ACHEVY's Avatar
So, been thinking about the MAC long tubes with an off road H pipe and now I am 2nd guessing the setup because it may be a little too loud and would attract trouble. (Neighbors/cops..etc). Also just found out that it would not pass a visual inspection. That being said, looks like I'd be going catted h pipe. Who sells a good one to go along with the MAC LTs? Thanks!
I8ACHEVY is offline
Quick Reply: Thinking of staying N/A mods?
