thumper cams
08-19-2009, 08:51 PM
thumper cams
does anybody have directions or instructions on how to install these? or do these cams come with instructions?
08-19-2009, 09:13 PM
08-19-2009, 10:17 PM
will i have to mess with a spring compressor? i didnt think these cams needed spring work. and yes i will be using the phaser limiters.
08-19-2009, 10:26 PM
and would auto zone have these special tools for rent??
08-19-2009, 10:28 PM
well if you want to do it fords way, you
do use a spring compressor.
can you do a cam swap without one, sure
but i personally wouldn't do it that way.
08-19-2009, 10:32 PM
hmmm ok, i kinda know some of the guys at the ford delership back in the shop, i will see if i can borrow some of there tools. i might even see if the guys could help me out.
pm sent regarding the tools
08-19-2009, 10:36 PM
and the spring compressor is only for removing the rockers right?
08-19-2009, 10:51 PM
i just did a member search and couldn't find that guy.
08-19-2009, 11:37 PM
try Anthony05GT it might be case sensitive
