Loving the Sound Induction Tube!
Old 08-08-2010, 06:36 PM
  #81
Heat00
Heat00's Avatar
ghettoct,
thanks. i got it out earlier. wow, its loud at WOT!
I was actually thinking the same thing, to cut it in half to give an inbetween sound level.
so you just cut to be shorter, but same diameter right? to fit right back in but now is half as long?
did that work out well?
I guess you could always put back together and stuff both halfs back in if not right?
Heat00 is offline
Old 08-09-2010, 04:20 PM
  #82
ghettoct
ghettoct's Avatar
Default sound
thats right, just cut half the length and iam sure you will love the sound, and can put the other half back in if you decide to go back to the stock sound. i personally love the half foam sound.
ghettoct is offline
Old 01-14-2011, 03:46 PM
  #83
willnapes
willnapes's Avatar
A few questions...
Under the hood, how do you get to the foam? More specifically, how do you separate the two parts of the sound induction tube? Do you twist them like a screw, or do you just need to yank on them?
Also, how many pieces of foam are there? I know there is at least one under the hood, and then another under the steering column.
Thanks in advance..
willnapes is offline
Old 01-15-2011, 03:35 PM
  #84
6+6 Stang
6+6 Stang's Avatar
can't remember how i took off firewall, but inside car reach up by clutch pedal, if have 6 spd, you can pull out, never pull one from under hood cause removed whole part, just look at page 1 and look all examples.
6+6 Stang is offline
Old 01-16-2011, 03:34 PM
  #85
08GTCA
08GTCA's Avatar
I was wondering about the foam plug in the sound induction tube.
If it is on the suction side of the intake air filter, and you remove the foam,
will the engine then suck in dirty unfiltered air thru that hole??
Is the foam actually an air filter of sorts??
08GTCA is offline
Old 01-16-2011, 04:43 PM
  #86
ghettoct
ghettoct's Avatar
foam can be taken out from the interior, there is a small hole in fire wall just by where your left foot would rest , just insert a nice pair of forcepts or tweesers and pull the foam out... that simple, its on the diaphagm side of the noise induction tube so no contaminated air can reach the intake. took all of 1 min to remove.
ghettoct is offline
Old 01-16-2011, 05:10 PM
  #87
MrSandman
MrSandman's Avatar
Had taken the foam plug out of the induction tube a while ago.. loved the sound. Took the foam out of the firewall today.. and it is MUCH louder.. surprised me even. I can see why maybe cutting the firewall foam in half might be a good idea. I'll leave it all out for now.. I can finally hear what the car is doing with the windows up
MrSandman is offline
Old 01-18-2011, 04:34 PM
  #88
5spdftw
5spdftw's Avatar
So there is the foam in the footwell as well as a piece at the other end of the tube? How hard is it to get that one out?
5spdftw is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Luke9222
10-22-2015 11:55 PM
BrantleyS550
09-14-2015 04:18 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Loving the Sound Induction Tube!
