Low 12 sec.
Old 02-22-2010, 09:51 AM
Silversurfer 3
Silversurfer 3's Avatar
Default Low 12 sec.
Hi everyone I'm new to the Mustang world of mods,I have a stock,gt mustang,with a 5 speed,what bolt ons do I need to get my stang in the low 12's?
Silversurfer 3 is offline
Old 02-22-2010, 10:08 AM
joutcelt
joutcelt's Avatar
it will be expensive but i would say gears, supercharger or turbo, suspension upgrades, and racing slicks
joutcelt is offline
Old 02-22-2010, 10:24 AM
dr.apex
dr.apex's Avatar
its deffinatley gonna need to breath too.
full exhaust system, for sure.
dr.apex is offline
Old 02-22-2010, 10:48 AM
Silversurfer 3
Big difference from my F body,will the ford racing supercharger get me there?whats the safest supercharger that I can bolt on and not have to redo the short block?Im trying to get as much as I can without opening the engine.
Old 02-22-2010, 10:49 AM
Riptide
Riptide's Avatar
People have hit low 12s without a supercharger. It's just easier to get there that way.
Personally, at sea level, I'd be damn disappointed if I didn't get into the 11s with a supercharger.
As far as "safe" goes the whipple with the canned tune is probably your best bet. It could still explode though. There are no guarantees.
Riptide is offline
Old 02-22-2010, 10:59 AM
dr.apex
dr.apex's Avatar
just to add to this a little. Boost levels are the main issue really. Pushing to much boost with out a strong bottom end is a sure fire way to have a bad day. Don't quote me on this, but on a stocker 8-10 lbs is usually anout the limit. Like i said, don't quote me, I could be wrong.
dr.apex is offline
Old 02-22-2010, 11:09 AM
Riptide
Riptide's Avatar
That's the conventional wisdom. Sometimes they go anyway and with even less boost than that.
Riptide is offline
Old 02-22-2010, 11:12 AM
Silversurfer 3
Thanks for the info,I heard 5 to 8lbs of boost was the limit,is the edelbrock charger a good one?what is the boost level?
Old 02-22-2010, 11:37 AM
Riptide
Riptide's Avatar
Cars have blown up on the dyno with as little as 360whp so it's always a crap shoot. I'm sure someone out there has put 12psi through a stock motor and been fine for a very long time, even after some abuse. Just a luck of the draw thing, up to a point anyway.
The edelbrock is fine but if I were you I'd get the whipple if you can afford it. Go to lethal's website and check out the new generation 2 models. Very impressive.
Riptide is offline
Old 02-22-2010, 01:09 PM
BRENSPEED
Former Sponsor
BRENSPEED's Avatar
We offer several packages that can easily get you into the low 12's and more like in the 11's. All of our kits are capable of those numbers at a safe boost level. A Brenspeed stage 3 Saleen typically turns mid 11's on 93 octane at sea level. Our Brenspeed E-force stage 0 puts out similar number as well. As for a centrifugal sc, our Paxton Novi 2200 and our Vortech V3 HO kit will also run 12's very easy and are easier on the engine do to the lower torque numbers off the line. Give us a call if you have any questions or feel free to PM my with questions.
574.594.9559
BRENSPEED is offline
Quick Reply: Low 12 sec.
