starting my Kenne Bell build
#111
That's exactly right. The drag radials will hook up so well the weakest link becomes the clutch. Mine starting slipping in third under heavy load with my drag radials. I put the stage II spec clutch with aluminum flywheel in mine and it holds very well. The only thing I didn't like about it was it had a long break-in period.
#112
I heard some people that didn't really like the spec stage 2 but the stage 3 is supposed to be pretty good.
on you meth kit where are you spraying it from? I'm assuming you're spraying it before the blower in either the inlet manifold or the intake. you doing 50/50 water/meth?
