Should LCA relocation brackets be welded?
Old 12-19-2010, 08:23 PM
lazyboy31614@aol.com
lazyboy31614@aol.com's Avatar
Default Should LCA relocation brackets be welded?
I have BMR LCA's and the relocation brackets and am looking to take my car to the track in the spring. Should the brackets be welded in to make them stronger? I will be running on some form of drag radial. (which tires to be selected at a different time)
lazyboy31614@aol.com is offline
Old 12-19-2010, 08:56 PM
SpartaPerformance
SpartaPerformance's Avatar
No. They don't need to be, I wouldn't.
SpartaPerformance is offline
Old 12-19-2010, 09:04 PM
This is a quote from Brenspeed's website about the BMR relocation brackets : "NOTE: It is necessary to weld the brackets in place if the vehicle will be drag raced." I'm just worried about hooking up and possible breaking the brackets or bending them.
Old 12-19-2010, 10:20 PM
Riptide
Riptide's Avatar
I've read of people running in the 10s without welding them.
That said. I wouldn't. If you are going to be launching hard on slicks or drag radials, and especially if you have a power adder, then get them welded in.
Riptide is offline
Old 12-20-2010, 10:10 AM
Simon1
Simon1's Avatar
YESSS!!!!
Totally necessary if you are going to the track. There have been several people on this board that pull a good 60' and wrap that relocate bracket around the back side of their axle.
Only takes a few minutes to do.
Simon1 is offline
Old 12-20-2010, 05:27 PM
Thanks guys, that is now added to my list of things to get done before taking the car to the track.
Old 12-20-2010, 07:19 PM
jz
jz's Avatar
I welded mine in. Wouldn't do it any other way.
jz is offline
Old 12-20-2010, 08:17 PM
SpartaPerformance
I know JDM uses the CHE reloc brackets on their cars and they don't weld them in, neither do I.
Old 12-20-2010, 08:21 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Make anote to the welder to do them in a way that it won't be a nightmare to get them off if need to be.
But yeah, for serious lauch, I'd weld them for sure.
pascal is offline
Old 12-20-2010, 08:54 PM
Here's hoping they don't need to come off haha, but yeah i'll make a note to the welder. Thanks for the heads up Pascal
Quick Reply: Should LCA relocation brackets be welded?
