Changed Brake Pads...E-brake loose...help
Old 03-09-2011, 01:21 PM
OSUTX440
OSUTX440's Avatar
Default Changed Brake Pads...E-brake loose...help
Changed my rear pads today....they are fine....broke them in just like I was supposed to. I didn't change anything other than that. There was no brake fluid or any fluid under the rotors. When I engage the e-brake...it is loose. It works and the car isn't moving....I pulled up on it about 20 times to reset it after I changed the pads...but...do I need to bleed the brakes out? Or is only when I am disconnecting hoses and what not? My logic would lead me to believe that this is normal because the piston in the caliper does not have to move that far...would I be correct?
And just for clarification...the e-brake does work...the car doesn't move.
Any thoughts?
Thanks
OSUTX440 is offline
Old 03-09-2011, 10:08 PM
OSUTX440
OSUTX440's Avatar
Bump.
No one has dealt with this?lol
OSUTX440 is offline
Old 03-10-2011, 05:13 AM
Boondoggie
Boondoggie's Avatar
It works, the car doesn't move, but it's "loose"?
define loose?
It sound like the cables need to be adjusted to take the slack out?https://mustangforums.com/forum/2005...cable-pix.html
Boondoggie is offline
Old 03-10-2011, 10:35 AM
OSUTX440
OSUTX440's Avatar
I will try that. When I pull the ebrake handle up...there is almost no tension in it. Like I said....it works...but I am worried that I screwed it up.
OSUTX440 is offline
2007StangV6
01-28-2016 06:09 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
Quick Reply: Changed Brake Pads...E-brake loose...help
