Oil separator?
Oil separator?
Yesterday I took off my PCV line because there was some grime on the valve cover and I was wiping stuff down. There was a good bit of oil in the line. Think it would be beneficial for me to get an oil separator? I try to keep all my maintenance perfect, I plan on keeping my car for a long time.
2006 GT, 39k, light mods
I run a oil seperator on my 06 "supercharged" (must have) and I also have one on my 93 sedan 331 NA. Ever since putting one on I have not had to clean the IAC or the throttle body. It would make sense to have just "air" going through the intake track and not airated oil that will eventually gum everything up.
I would recommend putting on any car.
You can make your own using compressed air filters from home depot or lowes, just make sure the drain closes all the way and does not leak air.
I've used several separators that way.
Regardless, keep that oil out.
