no air will blow for ac or for heat
Old 03-13-2012, 03:33 PM
ironh19
ironh19's Avatar
Originally Posted by cory21
its weird because everywhere i read it says that if the blower resistor is bad it only blows on high speed.. mine blows air on whatever speed i turn the dial too its just weak, seems more like speed 1 than speed 4... but ill give it a shot, looks easy enough
well who are you going to trust the internet or us?
ironh19 is offline
Old 03-24-2012, 11:18 AM
157dB
Cut & Paste Expert
157dB's Avatar
You are correct.
High speed is unaffected by the blower resistor.
Just the slower speeds.
It sounds like you have a plenum door thats partially blocked.
Items falling into the defroster vents on the top of the dash
can cause all sorts of problems.
Got kids with small toys? Set lighters on your dash?
Maybe the blower motor is on the partial fritz? Or maybe
your cabin air filter is plugged with leaves and trash
to beyond all recognition?
There are diagnostic procedures in the service manual
for just what you are now describing. Feeling up to
the task or are you just going to take it to the stealership?
157dB is offline
Old 03-24-2012, 12:18 PM
Mishri
Mish-ogynist
Mishri's Avatar
I had a similiar issue with my company vehicle ('97 GMC jimmy) it only worked if i had it set to ac before i started the car, then it worked fine on all settings, did that for about 2 days then suddenly started working normally again.. it was weird, I haven't had an issue since and that was probably 3 months ago.
Mishri is offline
Old 09-24-2012, 08:48 AM
effer2k07
effer2k07's Avatar
I am having similiar issues I will check these items listed here and let you all know what works for me... you guys all know your stuff
effer2k07 is offline
Old 09-24-2012, 02:33 PM
Blueper
Blueper's Avatar
Agree with 157dB
Sounds like you have a plenum not opening. My old mustang HVAC controller was operated via vacuum. not sure if the new Mustangs use vacuum to open the plenum.
If so, You need to check for vacuum leaks.
Blueper is offline
Old 12-06-2016, 07:29 PM
mhnamaki
mhnamaki's Avatar
Hi all,
I have the same problem. The fan doesn't work for both A/C and Heater. I can feel both A/C and Heater slightly in the cabin even at 4 setting.
The mechanic told me that the problem is for your "fan switch" and you have to change the "HVAC control assembly" totally which is very expensive (655$). Do you have any idea how I can change the switch by myself? Does he mean that the problem is the fan ****? or anything behind the control assembly?
He told me that blower motor and wiring are fine.
Thanks.
mhnamaki is offline
Old 06-29-2017, 12:27 PM
aayslnnelson
aayslnnelson's Avatar
Default A/C issue 2008 Mustang
Question. 2008 Mustang, my a/c just stopped working. The light doesn't light up when I press it, nothing sounds like it kicks on, nothing blows out. Literally NOTHING happens when I push the button. Could this be a fuse? What is most likely the issue? HELP please!
aayslnnelson is offline
Old 09-26-2020, 11:16 AM
Rj Garza
Rj Garza's Avatar
Was wondering if you found a fix to your issue
Rj Garza is offline
Old 07-07-2022, 07:34 PM
Slickbback19
Slickbback19's Avatar
Default Easy check
i have a 2005 mustang gt and recently when i turn on the fan either for heat or for a/c no air will come through the vents... the fan and everything seems to switch on as it should but it has no real power.. it doesnt matter whether the fan switch is on 1 or 4 its as if the air is just floating through the vents and not really coming out with any real force..
i replaced blower motor and nothing, I replaced the blower motor resistor and it turned on. Then next day it turned back off so I angrily just swiped the wires and boom it kicked on haha so i look at the connector to the fan motor and it was wiggling loose the clip broke so I just put a zip tie for now and it’s saying on haha.
Slickbback19 is offline
jwog666
12-27-2021 08:09 PM
PaulH2
20
01-31-2016 09:48 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: no air will blow for ac or for heat
