Going from 235/55-18 to 255/45-18...
Old 05-02-2012, 11:06 AM
157dB
Cut & Paste Expert
157dB's Avatar
Put some 16.5 tires on 16 rims before. He he he.
I used a 1/4" spacer all the way around.
Ford has a re calibrator but its for gear changes, not tire diameter changes.
A Tuner is the only way to compensate for larger tires.
You wont notice a small change.
235/50R18 STOCK
9.251" WIDE
27.251" TALL
85.641" ROUND
740 REVS / MILE
245/50R18
9.645" WIDE
27.645" TALL
86.851" ROUND
729 REVS / MILE
255/50R18
10.039" WIDE
28.039" TALL
88.088" ROUND
719 REVS / MILE
265/50R18
10.433" WIDE
28.433" TALL
89.325" ROUND
709 REVS / MILE
245/45R18
9.645" WIDE
26.681" TALL
83.821" ROUND
755 REVS / MILE
255/45R18
10.039" WIDE
27.035" TALL
84.934" ROUND
746 REVS / MILE
265/45R18
10.433" WIDE
27.389" TALL
86.047" ROUND
736 REVS / MILE
255/40R18
10.039" WIDE
26.031" TALL
81.780" ROUND
774 REVS / MILE
265/40R18
10.433" WIDE
26.346" TALL
82.769" ROUND
765 REVS / MILE
275/40R18
10.826" WIDE
26.661" TALL
83.759" ROUND
756 REVS / MILE
157dB is offline
Old 05-02-2012, 11:29 AM
waykooljr
waykooljr's Avatar
255/45-18's are approximately the same height as stock, so if the speedo hasn't been calibrated for the tires you have, there shouldn't be a need to re-calibrate.
waykooljr is offline
Old 05-05-2012, 09:32 PM
BAB GT
BAB GT's Avatar
My current 'stang has stock tire and wheel size, but the speedo is about 5% high vs. GPS. On other vehicles that I have changed tire/wheel diameter, I have just used my GPS for correction. I find the GPS speed much easier to read at a glance and I assume more accurate than even the OEM speedometer with OEM diameter.
BAB GT is offline
robs
08-06-2011 06:40 PM
Formula
Wheels & Tires
12-04-2009 06:56 AM
Shipwreck
10-20-2008 11:59 AM
Quick Reply: Going from 235/55-18 to 255/45-18...
