Built all motor 3V
Built all motor 3V
I have begun to get serious with the build of my car with all FRPP parts (I know there may be better stuff on the market but i want to keep it all Ford for a reason at least for the bolt-ons) and I have read articles where people have taken these to about 400 RWHP and 420 ish RWTQ. So my question is this. Has anyone gone this route with stock bottom end and valvetrain? If so has any issues came up? My build will include the following. FRPP TB,Intake,Bee hive ,Cams,Heads,Shelby fuel pump and injectors, then contemplating on a full Borla set-up for the exhaust, Comp-Cam valve beehive valve springs and a SPEC 2 clutch.
400 RWHP won't matter whether its FI or NA on a 05-09 or for that matter a '10 mustang. My '08 is cammed and blown at roughly 420 RWHP. I drive the snot out of it and have no problems. I'd say it comes to the tune as that is very important. Have a good tune and I would not worry at all about 400 rwhp. You won't need to worry about driveline, clutch, flywheel, block etc. until about 500 rwhp.
I have Roush supercharger, Steeda Cold Air, Ford Racing 3.73 gears, Ford Racing camshafts, Kenny Bell boost fuel pump (Highly recommend), Corsa x-pipe, Corsa Extreme Axlebacks, and a 93 race tune.
Double posted by accident. Apologies. :/
May as well say that the boost fuel pumps helps in high rpm ranges with fueling. When the shop ran a dyno test on my car it used 97% fuel and they had to back off before finishing the run. After putting on the Kenny Bell pump it finished the dyno run at like 77%, so it may be a good idea to look into.
Well i realize that it doesnt matter FI or NA although it will be a much different power band. It seems people are split 50/50 on what these 3Vs are capable of so I was just wondering if someone had gone the same route that I am planning on going. I think I am going to try and get it to Brenspeed for a tune im currently in TX but am from IN and will be back there shortly. I appreciate the info though
So it can be for you just have to decide what your going for.
Yep, I wouldn't try to spin the stock stuff that fast. I keep my redline stock.
