New set of tunes, what is the best procedure?
Old 04-16-2013, 02:41 PM
dcarlinf1
dcarlinf1's Avatar
Default New set of tunes, what is the best procedure?
I have only had one set of BAMA tunes so far for my SCT tuner. Now that I purchased an off road X pipe, I requested a new set of tunes. I was given documentation but I wanted to get advice from those that have done this before. So, what is the best/safest/smartest way to handle this?
What I have done so far: Received my new tunes via email and stored them on an external hard drive as well as in my gmail account. Same goes for my original tunes (I requested them in email as well). Can't have too many backups!!
Next steps: Update the firmware. My tuner is relatively new and may be up to date already. Gotta confirm that though. And, in doing so I should restore the car to stock first, correct? Once done I should be able to put one of my original tunes back on the car because I may not be doing the X pipe right away.
Drive a while ....
Then, install the x pipe and load one of the new tunes. Again, I have the documentation to do this. But, any advice or tips for replacing my original tunes with my new tunes on the tuner? Or, is it so simple that a cave man can do it?
Just looking to make this as smooth as possible so just looking for tips on how others have done this.
dcarlinf1 is offline
Old 04-16-2013, 03:11 PM
hootie_john
hootie_john's Avatar
Yes, make sure you go back to stock before you update the firmware. You'll need to install the drivers/tuner software on your PC as well before attempting to update the firmware. Be aware that the firmware update can take close to an hour. I wasn't aware of this and almost bricked my brand new tuner because I unplugged it during the update process, thinking it had hung. I got lucky and did some more research on the issue.
That's a good idea to keep a couple of copies of your tunes, things happen with PCs.
hootie_john is offline
Old 04-16-2013, 05:30 PM
Gary Ugarek
Gary Ugarek's Avatar
I just flashed over the others... no issue.
Gary Ugarek is offline
Old 04-17-2013, 09:32 AM
dcarlinf1
dcarlinf1's Avatar
Yeah, that's fine if you think you will never re-use your older tunes. I like the idea of keeping them all in a safe place. Of course, protecting and manipulating data is what I do for a living. I keep backups of my backups!!
Old 04-17-2013, 05:38 PM
Gary Ugarek
I keep my emailed tunes on my desktop, but I just flash the ECM with the new tune. I don't convert back to stock, then go to new tune
mtgldr
02-03-2024 09:00 PM
articman
06-21-2018 11:45 PM
TfcCDR
09-14-2015 12:08 PM
09-08-2015 06:25 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: New set of tunes, what is the best procedure?
