Next mod?!?
Old 04-18-2013, 08:16 PM
2009 Eleanor
2009 Eleanor's Avatar
Default Next mod?!?
Alright,
I have that itch again to mod my car. Appearance and interior are already done modding. So, what performance mod should I do next?? I want it to be under $250... I was thinking of doing off road x pipe?
I could do a roll control kit for around 200?
What performance mod should I do that will help my 1/4 mile times??? And no, do not say buy wheels and tires. I want a mod that I can use all the time, not just at the track like a set of slicks...
2009 Eleanor is offline
Old 04-18-2013, 08:32 PM
danzcool
danzcool's Avatar
used nitrous kit?
electric water pump.
port your throttle body.
underdrive pulley.
The roll control would be good for the twisties, probably won't help your 1/4, but it will be noticeable everyday.
danzcool is offline
Old 04-18-2013, 08:34 PM
2009 Eleanor
Originally Posted by danzcool
used nitrous kit?
underdrive pulley.
Whoops....
Hurst roll control=burnout switch
Old 04-19-2013, 01:48 AM
808muscle
808muscle's Avatar
With 430 gears do you have any traction at the drags? Tires are the most important part when wanting consistant ETs. Longtube headers gave me 2 tenths, cams gave me 2 more. Supercharger took off a second. Unfortunately $250 isnt gonna do that much. An X pipe wont help your times but may sound better depending on your setup. I say save your cash and get headers when you have more. Pypes are under $600.
808muscle is offline
Old 04-19-2013, 08:36 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by 2009 Eleanor
Alright,
This is the ORX I'm using. It sounds nice and makes good power.
http://www.uprproducts.com/mustang-o...x-pipe-05.html
UPRSharad is offline
Old 04-19-2013, 08:44 PM
2009 Eleanor
used nitrous kit?
underdrive pulley.
Is this a direct bolt on replacement?? I know pypes makes an orx for around $190 through am. Any idea how the power of pypes would compare to upr??
I have cervini exhaust which has some pypes parts on it. I kinda want to keep it all the same manufacturer. Any input on power and sound difference between the two?? Or will they essentially be the same?
Old 04-23-2013, 03:51 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
My honest opinion is that you probably wouldn't hear or feel a difference between the two, but ours is less expensive and it carries a Lifetime Guarantee.
Old 04-23-2013, 03:57 PM
Mustang Saber
Mustang Saber's Avatar
i would throw in a new performance chip kick up the power and torque check that bad bow out
http://www.cjponyparts.com/SCT-4-PRO...ccw4AodEh8Ayg/
Mustang Saber is offline
Old 04-23-2013, 04:01 PM
Mustang Saber
if i had the money i would change out the cams for some nice racing cams, port and polish, bigger fuel injectors, a new brain, then pro charge it, and you would have a fun street machine
Old 04-23-2013, 05:53 PM
krazykevin
krazykevin's Avatar
This only works up to 2004. So you would have to get a full hand held tuner, but I assume you are already tuned OP.
krazykevin is offline
Quick Reply: Next mod?!?
