Real difference between V6 and GT axle back?
Old 01-04-2014, 10:42 AM
AFMarksman
AFMarksman's Avatar
Default Real difference between V6 and GT axle back?
I recently replaced the Pypes axle back with GT500 axle back on my '12 GT. My buddy has an '11 V6 and wants my old axle back. They look the same, but AM shows different part numbers. Will GT axle back work on a V6? Thanks!
Dave
AFMarksman is offline
Old 01-04-2014, 10:50 AM
jesse1125
jesse1125's Avatar
From what I've read on the forums the GT exhaust pipes are bigger then the v6. You would have to have an adapter put in to make up the difference in size.
jesse1125 is offline
Old 01-12-2014, 03:33 PM
808muscle
808muscle's Avatar
Yes different pipe sizing.
808muscle is offline
Old 01-13-2014, 05:27 PM
JCON
JCON's Avatar
If it's the same as the 2005-10 v6 (2.25") and 2005-10 GT (2.5"), the mufflers should be able do ratchet down that extra 1/4". It has worked on all "GT" labeled axle backs for the earlier S197's.
JCON is offline
Old 01-13-2014, 07:03 PM
Moderator
JimC's Avatar
Sorry but that is not the case. For 2005-10 all Mustangs had 2.5"mid pipes and the axle backs were interchangeable. The down tube on the 4.0 were 2.25"with a step connection to the 2.5" over axle mid pipe.
Starting 2011 the 3.7 is 2.25" all the way, the 5.0 is 2.5" all the way, and the Shelby is 3"
Sent from my SPH-L720 using IB AutoGroup
JimC is offline
Old 01-14-2014, 05:51 AM
JCON
JCON's Avatar
I retract my previous statement. I've been out of my v6 so long I forgot I switched m pipes to GT pipes and that the Y on stock v6's went from 2.25" to 2.5" out. Thanks for catching that.
JCON is offline
Old 06-07-2014, 12:00 PM
strempert
strempert's Avatar
After a dual exhaust has been installed on an 06 V6, could I purchase the exhaust systems that say 05-09 GT instead of only the 05-09 V6 systems?
strempert is offline
Old 06-07-2014, 12:18 PM
Moderator
JimC's Avatar
Yes, the system is the same size for 2005-10 on both models after you remove the "Y" pipe on the V6 and use the step connector for the down tube connection, so once you go dual you can use any muffler or overaxle pipe for the 2005-09 Mustang.
JimC is offline
Old 09-01-2020, 05:56 PM
Colby Illingworth
Colby Illingworth's Avatar
I have a 2014 mustang v6 and I wanted quad tips can I use a quad exhaust system axle back or just the tips from a v8, they only make em for the v8
Colby Illingworth is offline
Old 09-01-2020, 08:24 PM
Moderator
JimC's Avatar
You can cut the single tip off and mount the dual tip. Most of those actually only use a single exit from the muffler. Might have to weld the new tips on.
JimC is offline
mtgldr
02-03-2024 09:00 PM
11-10-2015 11:39 AM
KingRando
10-01-2015 11:16 AM
UrS4
09-30-2015 10:13 AM
12bigredstang
09-24-2015 05:46 PM
Quick Reply: Real difference between V6 and GT axle back?
