New member / a few general Laguna Seca questions
Old 03-27-2014, 04:06 PM
priapism
priapism's Avatar
Default New member / a few general Laguna Seca questions
Hi all, I'm currently considering buying a friend's Boss Laguna Seca. I'm not familiar with Mustangs in general, nor this specific model...but I did a few laps in one and I was blown away!
Few questions:
Is the front splitter easily removable? I think it would get pretty much destroyed right away on our local streets. I was hoping to just put it on for track days, is that feasable or is it a gigantic pain in the ***?
Are the "Boss" 5-point harnesses a factory part? (He had 5-points that said "Boss 302" on them). Does the passenger seat have hooks for the 5-points as well? Is there any way to route the submarine belt properly?
He mentioned he had part of it painted...not sure how much. Is the silver with blue stripe a factory color?
Thanks all.
priapism is offline
Old 03-27-2014, 04:08 PM
priapism
priapism's Avatar
Also, anything specific I should look out for? It's a 2012 with low mileage, but they're mostly track miles...compression test came up good.
priapism is offline
Old 03-29-2014, 09:53 PM
ScrewedUp
ScrewedUp's Avatar
I'd leave it stock. That's going to be a very collectable car one day. Just my 2 cents.
ScrewedUp is offline
Old 03-29-2014, 09:56 PM
ScrewedUp
ScrewedUp's Avatar
Here's some info on the splitter install. Not sure bout the harnesses.
http://www.americanmuscle.com/boss-f...u-install.html
Old 03-29-2014, 09:59 PM
ScrewedUp
ScrewedUp's Avatar
Motors are pretty stout on these cars. The weak parts are the transmission. The MT-82 doesn't like to be thrashed. Ford should've put a T-56 magnum in there. Listen for gear whine make sure all gears work well and check if still under warranty. Everything else is usually solid as long as you change oil etc.
Old 03-29-2014, 10:01 PM
priapism
priapism's Avatar
Leave what stock? It's already been painted, if that's what you're referring to.
priapism is offline
Old 03-30-2014, 06:55 AM
priapism
priapism's Avatar
Thanks! I'll have to take a look and see if I can leave most of the hardware in place when I'm not using it....
priapism is offline
Old 03-30-2014, 04:23 PM
Nuke
Nuke's Avatar
Originally Posted by priapism
...Is the front splitter easily removable? I think it would get pretty much destroyed right away on our local streets...
If the splitter would get "pretty much destroyed right away" on your local streets, what does that mean for the rest of the car? You'd really buy a possible collectors car and then trash it on the street? I wouldn't even consider it as my DD.
Nuke is offline
Old 04-02-2014, 08:34 AM
priapism
priapism's Avatar
It's a car. I plan on driving it the way the engineers intended, not placing it on a revolving pedestal in my living room. Guess this isn't the right forum for these questions...
priapism is offline
Old 04-02-2014, 05:21 PM
CMcNam
CMcNam's Avatar
Pretty sure the front splitter is just bolted on, so you should be able to unbolt it. I'm not sure it's even legal to drive with it on. You'd definitely scrape it driving around.
Not sure about the answers to your other questions.
I'd encourage you to research some Mustang racing history just so you know what you're buying completely, but don't let that stop you from driving it either. The engineers intended for the Laguna Seca to be a weekend warrior, driven in anger occasionally on the track and maybe while you're getting groceries on a slow Saturday. It's a nice car (and extremely rare) so take care of it if you do get it.
CMcNam is offline
Quick Reply: New member / a few general Laguna Seca questions
