What could this be?
What could this be?
When at a stop and shift into first..sometimes its hard to get into first. It catches some or something. If i shift back into neutral and back into first it goes in smooth. What could this be? The parts that I have are in my signature. Any help is appreciated. Would this be covered under Fords warranty?
Mine does the same thing from time to time, same as reverse. Let the clutch out then push back then try, and let it roll a few inches back or forward and ittl go right in. Also when is the last time you've change the tranny fluid? When I changed mine at 60k it seemed to help the overall shifting smoothness..
Mine does it too. I run steeda tri ax and amsoil fluid. I forgot abou it until I read this. It's automatic muscle memory when this happens too; clutch, push into first, block, pull back and repress into first, bingo. Takes less than a second. Used to be annoying but seriously forgot about it.
