2010+ Mustang Shelby GT500 Billet Fuel Doors / Satin and Black
Give your GT500 a race car look with this Satin Silver Fuel Door made from a 5 lbs solid block of aluminum. They are machined down for a direct fit not bent or molded, then hand assembled with stainless steel hardware, precision ground stainless hinge spacer/washers, and nylon mounting bushings for a perfect fit that requires no drilling of sheet metal (although the inner plastic housing is removed during the installation process).
Retention and closing of the door is accomplished with cadmium-plated press-fit neodymium rare-earth magnets and an exclusive striker plate that is retained by stainless steel hardware, not loose-fitting glued-in components. Installs in about twenty minutes using common hand tools, and they are available in either black, or clear anodized with the side stripe GT500 logo machined into the door of the part.
Made in the U.S.A.
Just $149.95/free shipping
http://www.northamericantuning.com/2...p/nat-1832.htm
http://www.northamericantuning.com/2...p/nat-1831.htm
http://www.northamericantuning.com/2...p/nat-1830.htm
http://www.northamericantuning.com/2...p/nat-1829.htm
http://www.northamericantuning.com/2...p/nat-1828.htm
http://www.northamericantuning.com/2...p/nat-1827.htm
http://www.northamericantuning.com/2...p/nat-1826.htm
Made in the U.S.A.
S197 Shelby Section
09-03-2015 03:04 PM
inyadreems
08-21-2015 09:10 AM
08-14-2015 12:27 AM
