The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Estimate 1/4 times?
Old 10-22-2014, 10:44 PM
Stang-Nator
Stang-Nator's Avatar
Default Estimate 1/4 times?
2006 gt auto, before mods were: headers & full exhaust without cats, 3.73 gears, and a cold air intake. i had the car dyno'd before i put the air intake on, this was when i done the exhaust. i believe it put down around 285rwhp. i didnt have the car retuned after i put the air intake on, and had an engine light running lean.. the best time was a 13.5xx @102mph.
I just had ***** thumpr cams and 4.10 gears put on, and retuned the car and it now puts down 320rwhp and 325rwtq. The spare tire/jack is removed, and so is the carpet/wood that covers the tire well.
12s possible? I thought 12s were possible before cams, but I guess not.. must just be stick cars.
Stang-Nator is offline
Old 10-23-2014, 01:03 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Yeah, I'm in the 12's with the stock cams AND stock exhaust in a stick shift car, so I'm sure your car will also be capable of 12's. The only thing is that your Muthr Thumpr cams will have shifted the powerband to higher rpm so you'd probably need a higher rpm stall converter to get you there quicker.
Dino Dino Bambino is offline
Old 10-24-2014, 02:03 AM
808muscle
808muscle's Avatar
My 06 GT auto before the blower, I had 4.10s, cams, longtubes, no cats, cai, tune and sticky tires....best I could do was 13.13@106 mph. That was with a DA around 1200+. In good air 12s are very possible. Problem with an auto is you cannot launch hard. YOur best time will be when the motor is cool and launching off idle. Adding any rpm will cause the torque convertor to flash lower and slowing your car down. Your next option is to lose weight. Take everything not needed out of the car.
808muscle is offline
Old 10-25-2014, 01:51 PM
Simon1
Simon1's Avatar
Put some sticky tires on and you will be in the 12s easy.
Simon1 is offline
Old 10-27-2014, 07:52 AM
88 orangepeel notch
88 orangepeel notch's Avatar
+1 ^^^
What was you best 60ft so far? You knock that down and your there.
88 orangepeel notch is offline
mungodrums
10-07-2015 04:01 AM
StalkerGT
09-25-2015 02:41 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: Estimate 1/4 times?
