Rear Brakes 06 GT
Old 06-28-2015, 12:12 PM
jaejae
jaejae's Avatar
Default Rear Brakes 06 GT
Hi guys, I just installed new rear Rotors and pads on my 2006 GT.
I used Powerstop drilled and slotted rotors and their evolution ceramic pads.
I rented the special tool from AutoZone for the caliper piston and turned it until it would not turn anymore so I am 99% sure it is fully retracted.
The car feels like it decelerates faster than normal when I let off the gas or is under resistance from the brakes like they may be dragging.
I am getting a burning smell from the pads, but I read on powerstop's website that is
very common and is just the coating on the pads during "break in".
There is a decent amount of heat coming from the rear drivers side as well. And when I removed those old pads they were worn pretty uneven.
What would be causing this resistance/dragging? The rotors? Or the pads?
I do not want to screw up the car or roast the brake components. I have ready many conflicting things about Power Stop and have seen some others with similar issues but no fixes as of yet.
I have read it could be a frozen caliper but I don't want to replace the caliper if it could be something else.
Thanks!
jaejae is offline
Old 06-28-2015, 02:10 PM
Moderator
JimC's Avatar
Did you grease the slide pins on the calipers? They could be sticking and that could be the source of the uneven wear, heat, and resistance.
JimC is offline
Old 06-28-2015, 02:26 PM
BlindGUYnAR
BlindGUYnAR's Avatar
Just jack it back up and spin the wheels. There should be just a slight drag, but wheel should spin pretty easy. If one wheel drags quit a bit then figure out why.
BlindGUYnAR is offline
Old 07-03-2015, 06:10 AM
jpplaw
jpplaw's Avatar
Did you line up the indentation on the piston with the little pin on the back of the inside pad?
jpplaw is offline
Old 07-04-2015, 07:15 AM
Scott2
Scott2's Avatar
This was my first thought as well.
Scott2 is offline
mtgldr
02-03-2024 09:00 PM
Galactic
04-29-2019 02:56 PM
musnicki
09-23-2015 07:11 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
DoctorScary
09-09-2015 07:53 AM
Quick Reply: Rear Brakes 06 GT
