09 gt carpet replace
Old 03-23-2016, 01:55 PM
velozgt
velozgt's Avatar
Default 09 gt carpet replace
Thinking about replacing the worn and faded carpet in my mustang, anybody done this? is it something the average guy can do or is it a nightmare better done by a pro ?
velozgt is offline
Old 03-23-2016, 04:35 PM
danzcool
danzcool's Avatar
The hardest part is that there is a 2" strip that goes under the center stack console (radio area), to do it properly you would have to remove the center stack and that requires a lot of other dash removal.
When I put down sound matting I ended up just cutting the strip that goes under the center stack and adding some double stick tape under the leftover tabs, other than that it should be fairly easy, four bolts per seat, the center console is fairly easy to remove the, back seat bottom pops out, and then there's the rest of the trim pieces you will have to remove. You should disconnect the battery when doing this and wait at least 15 minutes before removing the seats due to the side airbags in the seats. For someone who has never done it before, it's a weekend job. If you've dome this kind of thing before and have the right tools (the trim fastener poppers), you might be able to get it done in 4 hours.
danzcool is offline
Old 03-24-2016, 12:39 AM
velozgt
velozgt's Avatar
Thanks for your reply, sounds like something I can do. Thanks for the heads up on the airbags never would have thought to disarm them.
velozgt is offline
Old 03-24-2016, 09:31 AM
movielover40
movielover40's Avatar
Would love some sound matting ideas.
movielover40 is offline
Simon1
01-24-2016 06:41 PM
tommy d
2.3L Eco-Boost Tech
01-18-2016 12:52 PM
Gun Jam
01-16-2016 08:19 PM
cominus
01-08-2016 02:47 PM
Quick Reply: 09 gt carpet replace
