CSF Radiators @ Lethal Performance.com!
Lethal Performance is now a distributor for CSF Radiators for your 2005+ Mustang GT/V6/Boss 302!
Here are some of the reasons why these are among the best aftermarket radiators:
"B-Tube" technology - Unlike a regular oval shape "O" type radiator tube, CSF uses a specially engineered tube in a shape of a "B". These "B-tubes" are carefully formed and then brazed over the seam to seal. CSF is able to use thinner and lighter aluminum material (better cooling efficiency) because this design is actually stronger than normal "O" shape tubes that are welded.
The design (inlet in the middle of tube that is seam brazed) increases the heat transfer surface area of the tube by approximately 15% over regular tubes. You get the efficiency of 2 smaller tubes vs. 1 large tube within the same space criteria. With "B-tubes" you are able to get "dual liquid laminar flow."
High Efficiency Multi Louvered Fin – CSF uses ultra efficient multi louvered fins that are carefully and precisely aligned to maximize airflow through each radiator core. Fin specifications are carefully measured and calculated for each application, and tested for maximum heat rejection efficiency in our wind-tunnel lab.
As an added benefit to equipping a CSF High Capacity Radiator to your mustang, each CSF Radiator is completed with a 1 HOUR HAND POLISH to create that "Show-stopper" mirror finish.
Click the image above, or check out this link for more details:
CSF 2005-2014 Mustang High Capacity Radiator
Call us @ 1-877-2LETHAL or check out online. Don't forget that you can earn Lethal Loyalty points, and ask us for your SVTP Member discount!
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
