Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
best mod's
Old 10-28-2009, 03:32 PM
  #61
GoTigersJoe
GoTigersJoe's Avatar
has anyone tried the MAF? I am thinking about upgrading to a Ford Racing MAF when I get my JLT Ram Air.
GoTigersJoe is offline
Old 09-30-2010, 08:51 PM
  #62
rygi23
rygi23's Avatar
From personal experience, another bolt-on that can go on the list is a firewall clutch adjuster (quadrant also, if it's in the budget). Good Lord it helps keep the power to the ground with the ultra-quick shifts and takes a load off the syncros as well. Combined with a short-throw shifter, the adjuster makes shifting a snap on the roads and helps performance at the strip. I strongly recommend the Fiore because of it's ease of adjustability but I hear the Steeda is a quality product as well.
rygi23 is offline
Old 10-01-2010, 09:46 AM
  #63
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
hook me up with the prices rygi and they will be put up there.
USMCrebel is offline
Old 10-01-2010, 05:24 PM
  #64
rygi23
rygi23's Avatar
I think the Fiore has been discontinued. Either put $45 for the adjuster itself, $80 for it and the quadrant, or $105 for the clutch adjust kit (adjuster, quadrant, new cable). Whatever you think's best.
rygi23 is offline
Old 04-23-2011, 06:21 PM
  #65
03_mach_won
03_mach_won's Avatar
Originally Posted by Mach1Fox
Excuse my ignorance, but what effect does the intake spacer have on performance?
i think the manifold spacer helps reduce heat traveling through the manifold to the head
03_mach_won is offline
Old 05-01-2011, 05:17 PM
  #66
XxMustangManiacxX
XxMustangManiacxX's Avatar
+1 this is definitely the best mod i have ever done to my car...and i dont miss gears anymore also
XxMustangManiacxX is offline
Old 06-30-2013, 08:15 PM
  #67
tomcat5157
tomcat5157's Avatar
just curious what size tb you guys have found to be optimal.
tomcat5157 is offline
Old 06-30-2013, 08:18 PM
  #68
tomcat5157
tomcat5157's Avatar
also was debating on lowering about an inch or so. any thoughts on springs?
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
firecoyote
09-27-2015 02:37 PM
Quick Reply: best mod's
