Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
well guys my bday is coming up
Old 01-24-2009, 11:51 PM
  #21
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
i can't find any prices on the sniper system...i'll still be a cheap bastard and go with the 100 Xcal II though
USMCrebel is offline
Old 01-25-2009, 12:14 AM
  #22
tws1098
tws1098's Avatar
Originally Posted by USMCrebel
tell me about the sniper system
Essentially it has a built in conservative tune, but with a wideband you could fine tune it for better gains. You can use it when you upgrade parts like exhaust and gears. You can create as many tunes for the car as you want and not have to pay for each one (as with other tuners). It comes with 2 tunes (so you could tune your car and another ford between 96-04 I believe). You can data log and analyze the data (it gives you a lot of info). There is suppose to be an update at some point that will allow you to do a "dyno" run on the street or at the track (giving you hp/tq)
tws1098 is offline
Old 01-25-2009, 11:50 AM
  #23
GTRACER88
GTRACER88's Avatar
Originally Posted by Furinox
remember if you get lt's you're going to need a tune as well for it to run correctly.
Are you being serious ?? When you get LT you do not need a tune to run correctly.
Originally Posted by rygi23
Much less backpressure with LTs requiring bigger A/F change, that's what I'm guessing anyway.
Nice guess... but no.
Maybe he is talking about getting a tune to remove the CEL light? The LT and O/R mid pipe take away 2 O2 sensors which will cause you to pull some codes. But there is no need to get a tune for it to run correctly.
GTRACER88 is offline
Old 01-25-2009, 12:07 PM
  #24
Stone629
Stone629's Avatar
Gt, you don't have to have it, but its a good idea, especially if you want to maximize your gains. Just slapping them on helps a good bit, but they don't gain nearly as much as they do with a tune.
Stone629 is offline
Old 01-25-2009, 12:13 PM
  #25
USMCrebel
USMCrebel's Avatar
i did some\looking, but still haven't found if lt's require a tune...most are saying no(which in my limited experience with efi crap is true) but like stone says it neds it to maximize gains
Old 01-25-2009, 12:44 PM
  #26
GTRACER88
GTRACER88's Avatar
Technically just tuning you car from stock form will gain impressive gains... But yes adding anything and getting a tune is always better.
Old 01-25-2009, 01:22 PM
  #27
tws1098
tws1098's Avatar
You can find the sniper software on ebay for around $350 i believe.
tws1098 is offline
Old 01-25-2009, 04:34 PM
  #28
USMCrebel
USMCrebel's Avatar
yeah that 350 is a turn off to me im a cheap bastard...hell if oil could be reused i'd do it
Old 01-25-2009, 05:54 PM
  #29
GTRACER88
GTRACER88's Avatar
Get a dyno tune. They can be as cheap as 150 dollars.
Old 01-25-2009, 06:43 PM
  #30
rygi23
rygi23's Avatar
WORD on that.
rygi23 is offline
Quick Reply: well guys my bday is coming up
