Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
11's with bolt-on's?????????
Old 02-07-2011, 02:34 AM
954mach1
954mach1's Avatar
Default 11's with bolt-on's?????????
I was just wondering if it is possible to get into the 11's with bolt on's. Its so expensive to go f/i which is why I was wondering because 11's is my goal in my street car.
954mach1 is offline
Old 02-07-2011, 05:01 AM
mrtstang
mrtstang's Avatar
I imagine it's possible with a lot of weight reduction.
mrtstang is offline
Old 02-07-2011, 06:27 AM
smitty2919
smitty2919's Avatar
That and driving the snot out of it. I would invest in a short throw shifter if you don't have one already.
For a decent track car I think you'd want
a whole suspension setup UCA/LCA/FLSFC
drag radials
maybe skinnies up front
weight reduction
maybe move the battery to the trunk
maybe even throw a small shot of the giggle juice top of all that.
smitty2919 is offline
Old 02-07-2011, 07:01 AM
everett
everett's Avatar
If you are bolting on nitrous yup
everett is offline
Old 02-07-2011, 07:12 AM
954mach1
954mach1's Avatar
My next mods were going to be springs, aluminum DS, and short throw shifter. I really dont want to do NOS, the stuff scares me.
954mach1 is offline
Old 02-07-2011, 11:50 AM
japan4racing
japan4racing's Avatar
you should be able to hit high 11's n/a. Its gonna take suspension work to do it though. build the rear end, get good uca's and lca's, adjustable shocks, welded torque boxes and axle tubes. after that you will be able to launch the car hard. then get some good exhaust, longtubes, 4.10's or more if staying n/a 4.56's may be the best for ya but will make interstate driving less that comfortable. get a tune! may need some weight reduction.
My car @ 3600+lbs on street tires runs 12.80's @ 111mph with a 2.1 60'...if I could get some slicks and lay down a 1.6-1.7 60' Im very confident my car would be close to high 11's. But I dont have that built rear so I would just snap an axle! Im going to try for 11's as well after I get money for the rear to be built up. if it wont go into the 11's its getting a 100 shot!
japan4racing is offline
Old 02-07-2011, 11:56 AM
BKAT
BKAT's Avatar
what's your mods?
BKAT is offline
Old 02-07-2011, 03:38 PM
954mach1
954mach1's Avatar
japan4racing what are your mods?
954mach1 is offline
Old 02-07-2011, 05:29 PM
rygi23
rygi23's Avatar
full bolt-ons, good tires, good air, good track, good driver...that's high 11s. No suspension work needed with proper clutch work.
rygi23 is offline
Old 02-07-2011, 05:53 PM
BKAT
BKAT's Avatar
that's what I was getting at......N/A 11's is very possible with our cars. Just need the right conditions, and right driver.
BKAT is offline
Quick Reply: 11's with bolt-on's?????????
