Massachusetts Regional Chapter Chapter President: Torch_Vert
Mass Chit-Chat
Old 04-18-2013, 10:04 PM
  #1011
Torch_Vert
Torch_Vert's Avatar
Originally Posted by RJDavis413
Not to sure, I get out of work in about 15 minutes so i'll be able to tell you then. (I don't think they do though)
The '05 and some '06 cars have them. Makes HID retrofits a bit nicer, as they block some of the HID capsule glare.
Torch_Vert is offline
Old 04-18-2013, 10:36 PM
  #1012
RJDavis413
RJDavis413's Avatar
Just checked and they do have the metal pieces
RJDavis413 is offline
Old 04-18-2013, 10:39 PM
  #1013
Torch_Vert
Torch_Vert's Avatar
Cool, I was hoping that would be the case.
Old 04-18-2013, 10:44 PM
  #1014
RJDavis413
RJDavis413's Avatar
Thanks for all the info.
Old 04-18-2013, 10:46 PM
  #1015
Torch_Vert
Torch_Vert's Avatar
No problem.
My first HID setup was like that (aftermarket retrofit into housings with the '05-'06 shields). Worked really well.
When I went to the GT500 headlights with the new nose, the shield type weren't available (First GT500 came out in '07, which was the year they dropped that type). Fortunately a very generous friend hooked me up with a deal on a set of factory GT500 HIDs (required some rewiring, but worth the work vs. the non-shielded standard housings).
Old 04-18-2013, 11:15 PM
  #1016
RJDavis413
RJDavis413's Avatar
No problem.
Torch yours is an 05 v6 5-speed right? Maybe you have my problem, sometimes when I'm coming to a stop (like just putting it in neutral from third) the engines revvs down but then pops back up to 2000rpms and just stays there for a while.
I've been told this is just normal for the transmission to wind down from higher rpms, but it just doesn't seem right, I've heard it only happens to 05 and 06 models, was wondering if you experience the same thing.
Old 04-18-2013, 11:22 PM
  #1017
Torch_Vert
Torch_Vert's Avatar
Well, it was a 5-speed until last year anyway. I swapped the transmission for a TR-6060 6-speed.
I honestly can't ever recall mine surging that high when going into neutral (or really surging at all then). I have been running aftermarket tunes almost as long as I've had the car though, and that might affect such behaviour.
Old 04-18-2013, 11:31 PM
  #1018
RJDavis413
RJDavis413's Avatar
I honestly can't ever recall mine surging that high when going into neutral (or really surging at all then). I have been running aftermarket tunes almost as long as I've had the car though, and that might effect such behaviour.
The amount of extensive (and expensive) mods that you have done is making me extremely depressed haha. But thank you, I'm not to worried because I have a 4 year powertrain warranty on my pony
Old 04-18-2013, 11:37 PM
  #1019
Torch_Vert
Torch_Vert's Avatar
Extensive I can't dispute, probably not as expensive as you might believe.
I'm a pretty good shopper for parts deals, and the labor is 99% "sweat equity" work by yours truly. Not paying a shop $75+ an hour brings the total outlay down fast.
Old 04-18-2013, 11:46 PM
  #1020
RJDavis413
RJDavis413's Avatar
Yeah me and my dad do all the work to our vehicles, he has an 09 Dodge Challenger R/T. I guess its just because I'm only 20 years old that 1400$ for a part seems pretty steep haha
Quick Reply: Mass Chit-Chat
