Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Step by Step guide to installing a Mark VIII motor in a 96+ GT.
Old 08-20-2014, 09:41 PM
  #141
tinkercameron
tinkercameron's Avatar
Default Quick question
Will the stock 97 gt fuel pump work? I was told it wont pump enough gas to the top end.
tinkercameron is offline
Old 08-21-2014, 10:44 AM
  #142
BlackMage
BlackMage's Avatar
yes it is fine. You want to make sure you bump up to the 24lb/hr injectors though. The 19's will be maxxed out.
BlackMage is offline
Old 09-02-2014, 03:55 PM
  #143
jakemarsh7
jakemarsh7's Avatar
what fuel rail am I supposed to use? I'm using the 96-98 cobra intake manifold, and I just realized that it doesn't have a way of using my fuel pressure regulator from my 99 GT.
jakemarsh7 is offline
Old 09-05-2014, 07:14 AM
  #144
BlackMage
BlackMage's Avatar
you need to run the 96-98 fuel rails
Old 09-06-2014, 07:38 AM
  #145
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Scored this little beauty yesterday. 132k on the clock out of a running 97 Mark VIII. I ran the motor for about 10 minutes at idle, then held it at about 3k then back down to idle. The oil was crystal clear, the coolant was nice and green, no foul smells from the exhaust and no clattering sounds. It ran smooth as silk so I think I'm in there.
fastbackford351 is offline
Old 09-07-2014, 07:58 AM
  #146
fastbackford351
Foghorn Leghorn
Now I am looking for the Cobra exhaust manifolds. I saw a set here locally on Craigslist that came off of an 03-04 Cobra for pretty cheap. Will those work?
Old 09-07-2014, 12:56 PM
  #147
jakemarsh7
jakemarsh7's Avatar
That's what I'm using, but 1) it is a return style system, while my 99 is returnless, and 2) it has no way of reusing the fuel pressure sensor from my 99
Old 09-08-2014, 06:51 AM
  #148
BlackMage
BlackMage's Avatar
yes, thats what i have. i had to cap off the air injection ports though. just used some brass caps for those.
Old 09-08-2014, 06:54 AM
  #149
BlackMage
BlackMage's Avatar
well that blows. hah. im not sure what you need to do, wonder if 99/01 cobra rails would work for ya. check out this thread, he put a mark 8 motor in his 02
http://www.moddedmustangs.com/forums...ap-thread.html
Old 09-08-2014, 09:54 AM
  #150
fastbackford351
Foghorn Leghorn
Thanks Blackmage.
Onward and upward!
Quick Reply: Step by Step guide to installing a Mark VIII motor in a 96+ GT.
