Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
'98 4.6 cobra motor into a '90 GT 5.0 body
Old 11-27-2013, 10:26 PM
the_stache
the_stache's Avatar
Default '98 4.6 cobra motor into a '90 GT 5.0 body
I'm coming into this project half way through... My brother started the project several years ago and I've finally decided to finish it. So far as I know I need a custom oil pan and drive shaft. Anything else I should know or keep an eye out for as I dive into this?
the_stache is offline
Old 11-27-2013, 10:28 PM
the_stache
the_stache's Avatar
Also keep in mind i have little experience with cars. I'm coming from a vintage motorcycle background...
Old 11-28-2013, 08:30 AM
pascal
S197 Section Modder-ator
pascal's Avatar
Do you have all the electronic hook ups (ECU etc...) that comes with the 4.6?
If not, brace yourself for a nightmare.
You might have to modify your trans tunnel not sure, but it's a minor mod.
Also, little things like engine mounts/radiator outlets correctness etc... need to be addressed.
pascal is offline
Old 11-28-2013, 11:05 PM
the_stache
the_stache's Avatar
Originally Posted by pascal
Do you have all the electronic hook ups (ECU etc...) that comes with the 4.6? If not, brace yourself for a nightmare. You might have to modify your trans tunnel not sure, but it's a minor mod. Also, little things like engine mounts/radiator outlets correctness etc... need to be addressed.
I have most if not all electrical. I believe motor mounts have already been taken care of. My main concern is the drive shaft. Apparently a stock driveshaft can be cut and rewelded to fit but i don't have the facilities or resources to accomplish this... Not with my dinky mig.
Old 11-30-2013, 01:42 PM
uberstang1
Chupacabra
uberstang1's Avatar
All you have to do is go anywhere that makes driveshafts and they can re tube your shaft to whatever size you want
uberstang1 is offline
Old 11-30-2013, 08:07 PM
the_stache
the_stache's Avatar
Interesting. Is it really that simple? What does something like that cost?
Old 12-01-2013, 03:59 PM
pascal
pascal's Avatar
Upon re-sizing your driveshaft, it will need to be balanced and this is not a step to overlook trust me.
The cost is around $150 if your U-joints are good.
pascal is offline
Old 12-02-2013, 10:55 AM
the_stache
the_stache's Avatar
Anyone know the length off the top of their head?
Old 12-02-2013, 04:21 PM
Steve@Tasca
Former Sponsor
Steve@Tasca's Avatar
Typically with a custom driveshaft you'll have to measure it out on your own, I'd talk to whoever is building the shaft and see what they suggest.
Steve@Tasca is offline
Gary Ugarek
09-05-2015 09:03 PM
Stilz
08-18-2015 09:40 AM
01blackgtconv
08-14-2015 04:50 PM
05slpGT
08-12-2015 02:32 PM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: '98 4.6 cobra motor into a '90 GT 5.0 body
