Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
351 into 94 v6 car T5
Old 07-24-2015, 08:35 AM
Frantz
Frantz's Avatar
Default 351 into 94 v6 car T5
I'm parting out my 95 F150 and want to put the 351W into my Mustang. I'm gonna do it dirt simple, so carb. I know I need a new oil pan and headers. I also realize long term the T5 (and axle) will be overcome, but for now it's going to be a less than stock motor (EFI makes more power than carb). What flywheel do I need to bolt these two together? If I'm doing no accessories and straight carb setup, I think I won't need much of anything.
Frantz is offline
Old 08-04-2015, 02:58 PM
Frantz
Frantz's Avatar
I figure since Ford Racing makes an oil pan for this conversion than I must not be too crazy.
Frantz is offline
Old 08-06-2015, 07:35 PM
pascal
S197 Section Modder-ator
pascal's Avatar
I used to know all this schit but my memory fails me.
Call Ford Racing tech line and tell them exactly what you're doing, they'll answer all these questions for you...flywheel etc...
You better pamper that T5 as the torque of the 351 will shred it quickly if you give it the berries.
pascal is offline
Old 08-08-2015, 07:40 AM
Frantz
Frantz's Avatar
Yeah, it's not the long term solution, but it is a "get the darn project on the road" way to go. I actually suspect I'd kill the axle first. Off to the junk yard!
Frantz is offline
Old 09-15-2015, 07:04 PM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
I am planning on doing the same thing..
im_stuck_in_iraq is offline
Old 11-16-2015, 10:22 PM
tarafied1
tarafied1's Avatar
Originally Posted by Frantz
I'm parting out my 95 F150 and want to put the 351W into my Mustang... What flywheel do I need to bolt these two together?
The 351W uses a 164 tooth flywheel while the 5.0 used a 157 tooth. The 94 and up 3.8 V6 had the 164 tooth flywheel so use the V6 Bellhousing and a 164 tooth 351W flywheel and the starter will line up. The Windsor and 3.8 V6 had the same belhousing bolt pattern so if your car is already a V6 5 speed you should be in great shape.
tarafied1 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
teeeeg67
09-01-2015 11:53 PM
movielover40
08-27-2015 10:13 PM
89blueslug
08-10-2015 07:20 AM
countrycannon8
04-26-2004 10:41 PM
Quick Reply: 351 into 94 v6 car T5
