Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Engine swap v6- coyote crate, questions.
Old 06-19-2012, 11:56 AM
Cburnett92
Cburnett92's Avatar
Talking Engine swap v6- coyote crate, questions.
So i was just wondering, if i drop a coyote crate engine in my V6 what all will i need to change out along with it so that it can handle it and future mods,
Cburnett92 is offline
Old 06-19-2012, 12:02 PM
kput
kput's Avatar
Suspension..rear end diff, driveshaft probably, tranny..all that jazz.
There's plenty of posts about this. check the search feature.
kput is offline
Old 06-19-2012, 02:10 PM
BWfVA
BWfVA's Avatar
There is ton of stuff that needs to be changed. I considered it but what really spooked me away was the wiring. I could get the engine and trans as well as the rearend and get a custom driveshaft made. The biggest thing for me though was getting the speedo to work with a 6 speed and all the electronics to work on the engine and still retaining my ac and other creature comforts
I going to swap in a 3v 4.6 and supercharge it, I believe it will be much more simple
BWfVA is offline
Old 06-19-2012, 08:34 PM
2005Redfire6
2005Redfire6's Avatar
+1 to going with a 4.6 3V over a 5.0 in our body style. I contemplated a 5.0 swap and my speed shop quoted me $13,000 with parts and labor... He also said that none of my gauges would work a long with other things since the electronics are different.
2005Redfire6 is offline
Old 06-19-2012, 09:02 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Can someone say: "Donor car"!!
pascal is offline
Old 06-19-2012, 09:52 PM
Tanner05
Chop Mod
Tanner05's Avatar
^ This would be the only way to do it.
There is a guy in Tulsa, OK who did the entire swap into his '06 GT and I mean the ENTIRE thing. He swapped in the interior and complete drivetrain. I called him and got a quote on doing the same to my car. He quoted me $20k to buy a donor 5.0 and put it into my car including the interior. Not a bad deal seeing as how a new 5.0 would run $30k+.
You might should consider doing a 3v 4.6. For the same price as a stock 5.0 swap you could do a built 4.6l swap and it would be much easier. I bought a donor GT for under $3k with everything I needed... that is cheaper than FI. The pricey part comes when you start to upgrade things....
Tanner05 is offline
Old 06-19-2012, 11:34 PM
99gt302
99gt302's Avatar
EDIT: nevermind, saw it was a 2010 car
99gt302 is offline
Old 06-20-2012, 06:11 AM
pascal
pascal's Avatar
$20K is so easy to beat it ain't funny...
I mean, it's only wrenching at that point, no fabricating.
Here:
http://www.sullivanperformance.com/fordhome.htm
This is what I want to do to my car... get a 5.4 from a Navigator (less than $1500) and use their much better aluminum intake and coil pack with own ECU and done.
No need for donor and head scratching.
You can even use a carburetor if you're in a cool State like FL.
Perfect set up for a classic car...
pascal is offline
Old 12-06-2015, 09:24 PM
101btp
101btp's Avatar
Where do you get 30K cost for a coyote 5.0??? Sealed engine 6,500 lol over 400 hp or 24,000 for a 575 hp engine? where are you getting 30,000 for the engine alone?
101btp is offline
Old 12-13-2015, 08:35 AM
jsimmonstx
jsimmonstx's Avatar
I'm pretty sure he meant an entire car for $30k...
jsimmonstx is offline
Quick Reply: Engine swap v6- coyote crate, questions.
