Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Lincoln 429?
Old 07-24-2016, 06:23 AM
rickieh
rickieh's Avatar
Default Lincoln 429?
I found a 429 for sale locally out of a 1969 Lincoln Continental and I was wondering if that was the same engine that the Mustang used for its 4:29 or if the Lincoln engine would be a bolt on or if it will require any modification to put in. I'd really like that extra hundred horsepower
rickieh is offline
Old 07-24-2016, 06:24 AM
rickieh
rickieh's Avatar
Just to clarify the Mustang I would be putting it in should it fit in a 1969 Fastback that already has V8 suspension
rickieh is offline
Old 07-24-2016, 05:03 PM
09GT/CS
09GT/CS's Avatar
probably not the same all boss 9s were hand built at another shop forget the name at the moment. But if I recall correctly they did some heavy mods to the inner fender wells and firewall to make it fit. It's by no means a direct swap.
09GT/CS is offline
Old 07-25-2016, 07:42 AM
88 orangepeel notch
88 orangepeel notch's Avatar
+1 ^^^
And yeah maybe 100 hp more, but that also comes with over 100 extra lbs. Your small block springs would be screaming lol.
I'm not saying not to do it, but it's definitely more work than a bolt in project.
Good luck
88 orangepeel notch is offline
Old 07-26-2016, 03:50 PM
jsimmonstx
jsimmonstx's Avatar
The lincoln never came with a Boss 429. The Mustang never came with a regular 429/460. The motor should fit between the shock towers, but for what it is, a stock 429 from a lincoln will not give you what you're looking for in terms of power, and the additional weight will make its presence known.
My advice is to build a stout Windsor, or at the very most a FE big block. In terms of money, I think the Windsor will give you the most bang for your buck.
jsimmonstx is offline
Old 07-27-2016, 10:30 AM
movielover40
movielover40's Avatar
The Lincoln 429 was a higher torque lower rpm motor for big car. Not a high performance motor.
Look for some of those 428 and 429 Super Cobra Jet motors they put in Mustangs and Torinos.
movielover40 is offline
69MACH1BUILD
04-10-2016 01:04 PM
mitchell1963
03-14-2016 12:32 PM
Drastang
02-20-2016 10:54 AM
crann11
17
12-21-2006 04:52 AM
MoreCubes
02-18-2003 11:16 AM
Quick Reply: Lincoln 429?
