Mustang II Section The more economy minded, compact Mustangs which were offered from 1974-1978
C5 Trans
Old 08-06-2007, 04:15 PM
workinonit
workinonit's Avatar
Default C5 Trans
is anyone running a C5 in there II.? I have a C4 and Im having trans problems. no 3rd gear..... Im looking at getting it rebuilt but Im not sure if I want to . I've heard that the C5 is much better because of the lock up converter. other than that its the same trans . does anyone use it? or have one for sale to a fellow stang II driver ? any feedback would be greatly appreciated
Thanks in advance
workinonit is offline
Old 08-06-2007, 09:15 PM
DonA
DonA's Avatar
Default RE: C5 Trans
Without going into all the detail you should know that two components have to work to give you third gear--One is the High and reverse clutch the other the forward clutch--Since you have forward in 1 and 2 the forward clutch is obviously ok---I assume that you have reverse--therefore the high reverse clutch is ok--However there is a tricky situation at work here--From the hydraulic standpoint the same pressure that applies the High/reverse clutch (in forward speeds) is also used to release the 2nd gear band--
If there is a hydraulic leak in that circuit the band will not release and the clutch will not apply. Therefore the first thing to check is the release side seal on the intermediate (2nd gear) servo which is the one on the front left side of the transmission behind the four bolts-
However be warned it is a tricky operation which may involve dropping the pan before you are done.
DonA is offline
Old 08-06-2007, 10:01 PM
my77stang
my77stang's Avatar
when my C4 went to hell, i didnt have any third gear. upon teardown, i found every one of the clutches inside were completely cooked and warped
C4's are excellent transmissions with minimal effort. Installing a upgraded servo, a shift improver kit, and alto red eagle clutches with kolene steels will make these transmissions hold up to ALOT of abuse for a very long time (these upgrades are actually very cheap, maybe a couple hundred bucks between them all)
my77stang is offline
Old 08-09-2007, 12:31 PM
workinonit
workinonit's Avatar
thanks for the input. I really didnt want to drop the trans so I droped the pan and went through the valve body. I put in a *trans- go* shift kit. well I have 3rd back but I need to get it back in the air and tighten the bands. something I should have done in the first place . Im still getting a slight hesitation on the 2-3 shift. I'll keep you posted ..
Old 08-09-2007, 02:46 PM
my77stang
my77stang's Avatar
i believe the upgraded servos help that 2-3 flare, ford used different codes for different vehicles.
the "A" code servos are the worst, the "H" code's are much much better, but aftermarket ones that are better than the "H" are onlly like 100 bucks. there are alco "C" code and "R" code servos, i believe both are better than an "A" code
Old 08-28-2007, 06:34 AM
andrewmp6
andrewmp6's Avatar
the c5 is kinda crappy id rebuild your c4 or go for a aod
andrewmp6 is offline
Old 08-28-2007, 11:06 PM
Colorado_Mustang
Colorado_Mustang's Avatar
C5 = C4+lockup circuit. If you have access to a C5, go for it. But, if you gotta buy a new tranny, I would go with an AOD-E and the controller. You'll like the electronic programming much more than messing around with the mechanical crap.
Colorado_Mustang is offline
Old 09-23-2007, 09:33 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ORIGINAL: Colorado_Mustang
and metric threads/bolt i beileve etc
rmodel65 is offline
Old 09-27-2007, 10:49 PM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
[sm=badidea.gif][sm=noooo.gif] i'm running one in my 67, and it ****ing blows, theres a reason they only made it for like 2 years or something like that......FORD said it sucked that means really dont put it in!
USMCrebel is offline
Old 10-20-2007, 08:01 PM
Blue coyote
Blue coyote's Avatar
ORIGINAL: USMCrebel
Uhm, the reason they only made the C5 for a couple of years is because with their usual (lack of) wisdom, they replaced it with the A4LD...basically a C3 with a lockup converter AND and overdrive gear, then only installed half of the planetary gears on all but the 4.0 litre models. Now THAT tranny blows....literally....
Blue coyote is offline
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
2poor4u2
09-26-2015 11:08 AM
97SN95GT
09-13-2015 09:45 PM
Quick Reply: C5 Trans
