Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Mustang II Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-21-2008, 02:18 PM   #1
Eclipzed
Default My carb sucks.
So... I'm hitting a new issue where Natalie (the car) is suddenly choking. Talking to my friend with the other Mustang II, he suggested that the things that inject the fuel are maybe getting stuck. So he suggested this stuff made by like sea foam or something called Engine Tune. So I put that in my gas tank, and its helping a little...
Heres my real question though. I'm a little annoyed at my duel carb. Cause I cant put like an edelbroke air intake on it. Cause it has the two screws instead of just the one... Is there a carb I should switch to to get more power, and to be able to use the intake? Or should I just keep mine, and find an intake that will work on mine?
I'm really wanting to find ways to get more power out of this engine. I have a tough time believing that this 2.8L V6 can really only push 111 HP. I mean... My Mazda 626, which was a 2.5L V6 (And had a cylinder out) was pressing 160ish... Granted that was with performance parts. But still...
What can I do to make Natalie a beast? But still run dependable?
Eclipzed is offline   Reply With Quote
Old 02-21-2008, 08:13 PM   #2
my77stang
my77stang's Avatar
Vehicle: 77 II, 06 GT
Send a message via AIM to my77stang Send a message via MSN to my77stang Send a message via Yahoo to my77stang
Default RE: My carb sucks.
offenhouser makes intakes so you can use a holley 4bbl carb on there (you'd want a 390 cfm), and larger cams are available. do that, then add dual exhaust and you'll be much happier...... but in the end its just a 30 year old 2.8 V6[8D]
links:
http://racerwalsh.zoovy.com/product/...r__Bronco.html
http://store.summitracing.com/partde...p;autoview=sku
http://racerwalsh.zoovy.com/product/..._1_26__28.html
OR
http://racerwalsh.zoovy.com/product/..._2_26__28.html
they also have supporting mods like valve springs, better distributors, gasket sets, etc etc
__________________
my77stang is offline   Reply With Quote
Old 02-22-2008, 12:46 AM   #3
Eclipzed
Hmm, That camshaft V2, and Holley carb looked nice. or am I wasting my time? Should I just bump it up to the 302 V8?
*sighs* I feel bad cause she wants to go fast. I can feel it.
Cept, the suspension is shot, the brakes are shot, trannsmittion could use some TLC... And same with the engine.
Old 02-22-2008, 09:43 AM   #4
my77stang
my77stang's Avatar
you'll always be better with a 302, but converting everything will cost alot more. it all depends on what power you'll be happy with.
fixing up the 2.8 will make it quicker, it will have pep - but it will never be FAST
__________________
Old 02-22-2008, 10:15 PM   #5
Eclipzed
Mmm. I had a 99 GT do a blow by on me. Made me sick to my stomach, I floored it and she couldent even barely keep up.
Whats a rough estimate for a 302 swap? Anyone know?
Also. shes going back to chocking agian. But then agian, I sorta jumped her on accident. Coming down a hill, there was a bump, got a little air, but then since the shocks are shot, she hit the ground, hard... It feels like the same problem as before with the injecters (or whatever they are) Cept... Its back. *shrugs*
Old 02-22-2008, 10:49 PM   #6
my77stang
my77stang's Avatar
lol
302 swap would cost as much as the motor you found, plus all the conversion stuff. ebay can be your friend here, but motor mounts, headers, bellhousing, flywheel/flexplate, torque converter, radiator, oil pan, oil pickup tube can all add up.
__________________
Old 02-22-2008, 11:03 PM   #7
Eclipzed
Sounds like I need to start making a list. What are my options as far as V8's go? Am I basically limited to the 302? Are are there bigger engines I can put in? With out breaking the bank. lol.
I basically work at a gas station. So... You get the general idea of how much I make.
Its to bad shes a Ghia. And not like a Mach 1 or something...
Old 02-28-2008, 09:34 PM   #8
Chaz78StangII
I was dogging 4 cyc Stangs earlier with my wife and she said, "you have a 4, so why are you talking crap about them?" I said, "I have a 6", she says, "no way, it runs like a dog"..
Chaz78StangII is offline   Reply With Quote
Old 03-01-2008, 06:08 AM   #9
andrewmp6
But your 2.8 will have more torque then your klze 2.5 mazda v6 for those who don't know.
andrewmp6 is offline   Reply With Quote
Old 03-09-2008, 03:34 AM   #10
Zerax
Try rebuilding the carb. Might take care of the "shrugs"(?). That little 6 is quite capable of some speed but it can depend on the tranny and the rear end. I had a 74 fastback that could chirp tires in the first three gears (it hand the 4-speed). If you gave the auto, consider the 4-speed manual...
Zerax is offline   Reply With Quote
carb, klze
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
