Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Mustang II Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-16-2009, 09:55 PM   #1
Micah1234
Default Timing a 302
Can i have a procedure how to time the crank with Cam shaft, I cant see the two dots to line them up?? is there a procedure on this? thanks alot, also what is the firing order? its for a 1976 Cobra II 302 5.0
thanks
__________________
1976 Ford Cobra II
Micah1234 is offline   Reply With Quote
Old 04-16-2009, 11:13 PM   #2
superhulk117
1978 Ford Mustang
Vehicle: 1978 Ford Mustang II Ghia
Are you using a timing light and cant see the advance?
what do you mean?
Firing order didn't change much.
Newer-->H.O. 302's: 1-3-7-2-6-5-4-8
non-H.O. 302's & 351W's: 1-5-4-2-6-3-7-8
Yours would be the second one here.
__________________
78 II Ghia
5.0 w/ AOD
stock 2bbl carb
stock exhaust
85 serpentine belt system
140 amp alternator + dual electric fans
superhulk117 is offline   Reply With Quote
Old 04-17-2009, 01:00 AM   #3
mstngsule68
k if u mean puttin the timing gears on, then there is 2dots that line up, u gotta find them maybe its on backwards or something..... and if u mean using a light, then use the search function
__________________
'87 stang with some goodies on it
'68 stang being restored
"Even one weakpoint, is STILL a weakpoint. Don't make any"
mstngsule68 is offline   Reply With Quote
Old 04-19-2009, 02:54 AM   #4
superhulk117
1978 Ford Mustang
oh, i didn't understand. lol. I was meaning when its all together using a timing light to find the numbers on the harmonic balancer. but you can't find the dots on the timing chain... well, i'm not sure, is the chain dirty or worn down for any reason?
__________________
78 II Ghia
5.0 w/ AOD
stock 2bbl carb
stock exhaust
1976, 1978, 302, 3o2, 94, chain, change, cobra, firing, ford, gears, ii, line, mustang, order, procedure, timing
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
