Oil and Oil Related Topics A place to post your oil related questions and comments
Synthetic back to conventional oil
Old 11-13-2010, 11:02 PM
19stang88
19stang88's Avatar
Default Synthetic back to conventional oil
Is there any harm going back to conventional oil after running synthetic oil for about two years? Main reason I want to change is cheaper oil
19stang88 is offline
Old 11-14-2010, 09:45 AM
DreamerGT
DreamerGT's Avatar
Nope no harm will come to your engine.
DreamerGT is offline
Old 11-14-2010, 01:59 PM
MU71L4710N
MU71L4710N's Avatar
might be cheaper but with synthetic your changing your oil FAR less. if you use amsoil or similar with 10k+ OCI's your changing oil 1/3 as often as regular conventional. so the initial cost is higher, but your not spending 20$ every 3k miles on a cheaper oil change...
MU71L4710N is offline
Old 11-14-2010, 02:00 PM
MU71L4710N
MU71L4710N's Avatar
might be cheaper but with synthetic your changing your oil far less often. 10k+ with a good synthetic vs 3k with any standard conventional.... while it may cost more for that one oil change your changing oil 3x as much with cheaper stuff.
Old 11-14-2010, 02:22 PM
19stang88
19stang88's Avatar
yeah i know running synthetic last longer and in the long run it will be cheaper, but i have leaks so having to buy $8-$9 for each quart of oil when i get low is spendy.
Old 11-14-2010, 02:41 PM
ShadyNinja
ShadyNinja's Avatar
leaks?
gaskets are cheap
ShadyNinja is offline
Old 11-14-2010, 03:21 PM
MU71L4710N
MU71L4710N's Avatar
have you tried some high mile oil?
Old 11-14-2010, 04:41 PM
Unleashedbeast
Unleashedbeast's Avatar
No harm will come, go ahead and switch. I agree with people who have leaking engines, synthetic is too much for waste via leaking.
Unleashedbeast is offline
Old 11-14-2010, 07:01 PM
DreamerGT
DreamerGT's Avatar
Originally Posted by ShadyNinja
leaks?
gaskets are cheap
True, but depending on which gasket it is can be expansive. Unless he can do it himself.
Old 11-17-2010, 05:51 AM
uberstang1
Chupacabra
uberstang1's Avatar
Usually on the 302 engines with age the big leak bandit is the rear main seal which is a cheap seal but by no means is an easy fix for a basic DIYer. Also replacing a rear main seal is a costly job at a shop and if the leak is "gushing" its probably easier/cheaper to just add oil between change intervals which would justify using a cheaper based conventional oil.
uberstang1 is offline
Quick Reply: Synthetic back to conventional oil
