Boost cooler is in!
#71
RE: Boost cooler is in!
Booster cooler in its self does not make power, what it does is cools down your intake
air temp, so that you can either run more boost or a more agressive timing with same
boost and not have to worry about detonation.
The boost cooler kit comes with an MAF interface that changes the amount of
water/meth injected by how much air the engine is getting.
You estiamte nozzel size by how much hp your making, and it sprays into the throttle body usually.
ORIGINAL: wwmost
sweeet. now clean your engine bay. is it like nitrous? does it spray at wot or a btton?
ORIGINAL: nanaki
nothing like a nice clean install. the pump and safe injection is mounting below everything behind the tire. like under the resevoir basically. can't see anything! you can see the nozzle in the second pic. this thing hauls some serious **** now.
http://nanaki.realns.com/images/3.JPG
http://nanaki.realns.com/images/4.JPG
#72
ORIGINAL: r.barn
ORIGINAL: wwmost
ORIGINAL: nanaki
it makes power by cooling the intake and acting as an octane booster. some have claimed up to 120 octane. i don't know about that unless you're running almost pure meth. i'm only running 70/30. i could get their 50/50 mixture and squeeze some more out of her, but i'm at the limits the way it is. [&:]
jwog666
12-27-2021 08:09 PM
