Pulley size Vortech S- trim/ Methanol injection
RE: Pulley size Vortech S- trim/ Methanol injection
ORIGINAL: luckythirteen13
go to google and search "reichard racing" it finds the site but the site doent work
what i would do, just buy whatever size you want pulley from vortech or ebay or anywhere, take it to a machine shop along with a photo of the ultra grip pulley and tell them to do the same thing to your pulley. its just a few holes drilled into a reglular pulley
yea what exact blower do you have i have a t-trim and vortech says its most efficient at 26psi see and i think the S and Sq's say 20psi
VORTECH V-1 T-TRIM SUPERCHARGER
The supercharger of choice for street/strip vehicles with modified engines
Straight cut spur gear
Fits engines up to 825 horsepower
Maximum airflow: 1,200 CFM *
Maximum boost pressure: 26 PSI *
Maximum impeller speed: 55,000 RPM
Adiabatic efficiency: 73% **
Available with straight or curved discharge and clockwise or counterclockwise rotation
* Flow and boost ratings are based upon efficiency. All Vortech superchargers can exceed these ratings but they cannot perform efficiently above these ratings. Vortech uses an efficiency rating of 60% and above as the approximate minimum usefull range.
HRnB
13
04-13-2022 04:06 PM
spederman
07-11-2006 11:40 PM
