Choosing a Kb?
#31
RE: Choosing a Kb?
Any Chance a kenne bell would fit under my shaker? Just wondering for after the winter, because s/c is one of the things i been looking into.
#33
RE: Choosing a Kb?
ORIGINAL: TheBob98GT
your crank will hold at 400. a buddy of mine has forged pistins and rods with stock crank and it holds just fine. he's got a paxton centrifugal on his GT and runnin a little over 400hp and 400tq with 20,000 miles on motor. dont worry about crank as long as u dont go racin it every other day.
If you can't afford to do the build with the crank, you can't afford to do the build at all.
#34
RE: Choosing a Kb?
whatever you decide to do with your car, use centrifugal force over roots just because of the consistancy of boost throughout the rpm range. also, any bolt-ons you put on the car, have them all geared toward a blower application, that is if you do end up with a blower. otherwise, you're just thowing your money away on stuff not needed. finally, i think that buying a kenney bell blower is more paying for the name than it is for the technology and performance.
#35
RE: Choosing a Kb?
I knew a guy with an 01 Saleen with a stock botton end who was running 14 psi all the time, his philosophy was if it breaks, he'll fix it. He ran 14 psi for over a year without hurting it, and he raced it a fair amount. He finally had a rod go, but it took a while. -Conversly, I knew a guy with a 01 gt who was making 13 psi and first time out to the track a rod went. 4.6 bottom ends are a crapshoot.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Gary Ugarek
08-26-2015 08:41 AM
