Turbo Vs. Centrifugal Supercharger
RE: Turbo Vs. Centrifugal Supercharger
ORIGINAL: ajmodelski
I think that is the right name Centrifugal Supercharger, the pro-charger kind. Anyways, I'm considering going super charged or turbo charged. I'm totally addicted to the blow off valve sound, and I love the idea of not having to get into boost when I don't want to. However, I already have a full exhaust system, and I'm not too crazy about having to hack it up or get new stuff. But either way, I still need to know. What is the benefit to getting the centrifugal supercharger over the turbo charger. And, considering i'm only really interested in about 500hp. Not much more if any. What is the best?
I have the Procharger. It may wellbe that a turbo is better...don't know that much about FI. You should research both s/c and turbo with equal vigor. But the Procharger does produce good power, is very upgradeable, sounds like a jet engine and has loud blowoff noise.
View the link for a very short test drive from last week after a dynotune. Ripping through 1st and 2nd takes less than 3 seconds now.
http://s149.photobucket.com/albums/s76/forensicsteve/?action=view¤t=streettest1.flv
Really just arguing costs....a procharger isnt all that much cost worthy. A decent kit anyways, like a ATI unit will run you almost 5+ grand when its all said and done and if your not putting it on yourself tack on some more. A Hellion kit is around 6,500 i believe havn't looked inawhile and it comes with pretty much every nut and bolt you need to put it in. A procharger kit isnt going to include your injectors and everything else, just the supercharger kit. I believe, but may be mistaken, the hellion kits lnclude a fuel pump, injectors and MAF. Plus it keeps your air conditioning.
But either way you go your still going to have it tuned. Thorwing a S/C or a turbo on a car with no extra tuning is a kinda stupid thing to do in any case, i dont care if your only running 5psi or 50. You need to have it tuned and thats going to cost money to.
Plus there isn't a point in putting forged internals into your stock block. Spend the money elsewhere. The stock insides are stronger than the stock blocks. There was a guy on turbo mustangs.com who made so much power with a MP T-70 and had like 130 passes or something like that on a stock long block, he finally turned the boost up to around 20psi and ran it about 10 passes on that.before hefinally bent like three connecting rods. But he didnt really care, it was a stock motor, he pulled it and replaced it with another stock motor. But the point everyone on the site was amazed about is his block didnt crack before the rod bent, its extrememly rare a rod or piston breaks before the block unless your a dumb *** and trying someting stupid. Theres guys on there makeing 600hp on stock long blocks, they might only last about 50 passes or less though, i think the record is like 300 passes or something before a block failure. Check the 'castastrofic' failure section on the site. They give complete lists of their mods, tunes etc and how many passes/ street miles they had on their engines before they broke.
ORIGINAL: 88stangaruu
And yes it does sound like a jet, and has a mean Surge valve, but I actualy wish it didnt sound that loud, it doesnt take too long for everyone to figure out you have a SC. I was very close to getting a turbo setup, but I dont really see having my block rebuilt in the near future so I wouldnt use it to its full potential and be spinning my tires even more than I do now.
Oh by the way you can tell procharger what you have done to your car as far as the exhuast system on the phone before you get the kit and they will tune the chip they give you for it, pretty sweet. Procharger made me very happy except for the stock intake actually....melting...get a powerpipe...trust me.
I was going to do a Turbo on mine, but ended up doing a SC instead. It is almost completed, and should be road ready in 2 weeks. This is not a Kit, so it did take some fabrication and mods to fit correctly. This is a Vortech YSi, to a carbed 393.
The Blow Off valve is sitting on the shock tower, and will be installed this week, and vented to under the fender.
Full Details: http://members.tccoa.com/392bird/sup...gerinstall.htm
Turbo :
- Expensive if a Kit
- A lot of Fabrication of Exhaust tubing if not a kit
- No Parasitic Loss so More power
- Turbo Sound, blow off valve
- Fewer "complete" kits
Supercharger (centri)
- Cheaper then a Turbo setup generally
- No Fabrication required, just bolt on and go
- Lots of complete kits to choose from
- Supercharger sound, Rush of air or flutter from Bypass Valve
- Parasitic loss, less power then a turbo
E.
E.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
2011, blow, boost, centrifugal, flutter, fox, mustang, stock, supercharger, superchargers, turbo, untuned, valve, vs, ysi
